Results 1 to 19 of 19
    Jun 2011
    Arizona
    Default how to shift SE-5 trans
    I've been waiting to buy a new ST and reading as much as I can. I have a few questions on shifting the SE. When you are stopped at idle with the foot on the brake, does the transmission always go to neutral or can you be in gear?
    When starting out from neutral, do you upshift or downshift to first gear? (is neutral between 1 and 2 just like a manual?)
    I've never driven a paddle shift vehicle so forgive the simple questions. Thanks.
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    It stays in first gear while stopped, foot on break. Neutral is not between 1st and 2 nd.
    Nov 2012
    Albuquerque, NM
    Quote Originally Posted by azjerry View Post
    It is always in first gear when you slow down and/or stop for any reason (nice feature, you never have to wonder if you're in 1st). The gear order is R, 1, 2, 3.........
    Jun 2011
    Arizona
    thanks all.
    The only time that it'll pop into neutral, s if you start it up while it's in gear.
    Default Interesting..!!
    Have a manual and always have. Never ridden a SE so I learn a little more here.. Thanks
    Oct 2008
    Fort Collins, CO
    It was a learning curve going to the SE. I was rolling out of the throttle and then learned its much smoother to maintain the throttle and just click the paddle
    Jun 2012
    Hampton, Virginia
    Post
    .....with your foot depressing the brake pedal. N is between R and 1st.
    They have you covered on your basic question.
    Additional points. Upshifting. You will find a "sweet spot" usually between 4500- and 5500 rpms for the upshift. Crank throttle, when reaching the sweet spot, punch the paddle shifter. Gear will change without any klunk and will give you a seamless shift. Do not let off the throttle when making the shift.
    Downshifting: The will downshift automatically, or, you may find it more seemless to hit the button at about 3500 rpms on the dowshifts from 5th to 2nd, and 2500 rpms on the shift from second to first.
    The transmission seems to be happiest in that 4500-5500 rpms. Fifth gear is recommended for 65 mph and over--so you don't lug the .
    A bit of practice will help you find the sweet spot on yours.
    Jun 2010
    Las Vegas
    I feel like a fish out of water on the SEs! I can never figure out how to get it in reverse.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2012
    Houston, TX
    Quote Originally Posted by SpyRyd View Post
    yup, accidentally tap the down shift while stopped at a light and you'll be in neutral.
    Jun 2011
    Arizona
    OK, thanks for all the help. I misunderstood what I read previously, I think I got it clear now. Hopefully in a week or two I'll find out.
    YOu're going to have to let us know what you think of your new pride and joy as soon as you get it home!
    And of course; lots of pictures!
    Jun 2011
    Arizona
    finally got it today. Here is the wife riding it. I rode it home but I have a feeling that is the last I will get a crack at it.
    Jun 2011
    Arizona
    It was an interesting ride for me. I've never ridden a trike of any kind. I rode it around the dealer parking lot for a few minutes then headed home. Got up to about 65-70 for a short distance on the way home. Very different from what I am used to but a lot of fun. The wife has only had her license for a month, she took the basic MSF on a Wing trike, so we went to the Walmart parking lot and after about 45 minutes, she was really comfortable on it. She knows she still has a lot of learning but she is really excited. I'm a little sad, I don't think I'm going to get much seat time on it.
    washington state
    The more you ride the better it get, have fun
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    on your new purchase....(should of bought two)
    2008 GS.....PE # 2888
    Apr 2011
    Weatherford, Tx
    Some of us just HAVE to learn the "Hard Way"!!! Bandit
    Jerry,
    I think that you're going to have to revisit the dealer and get that second bike...
    Have you had any riding time on ATVs? That might help to make the transition a bit easier.
