Its official: BajaRon's swaybar is a MUST have for all RT owners!
Arrived, installed and tested!
All I can at is OH MY FREAKIN' GAWD! THIS THING IS AWESOME, A MUST HAVE FOR ANY RT OWNER!
I noticed a difference from the first right hand turn in my neighborhood at 25MPH and it only got better in the twisties!
I took an unfortunately short ride in some of the twisties I am most familiar with and the difference is amazing! Turns that uses to put a little fear in me where smooth as glass at higher speeds than ever before.
I do see one downside for Ron though, he is probably going to be selling fewer brake pads as a result of this amazing performance enhancing product.
Well done!
Kinggeek
Mandeville,LA
VERY HAPPY Spyder Ryder!
Where have we been on the Spyder? See below:
Can-Am Spyder ST-S SE5 in Congac
![](http://badges.fuelly.com/images/sig-us/310412.png)
RT sway bar
Do you have the stock shocks or Elka's?
I have Elka Stage 1+R all the way around.
I will say this though for RT owners with stock shocks. The BajaRon Swaybar should be the first suspension performance mod you do. It is significantly less expensive than Elka shocks on the front and provides exactly what most are looking for when they replace the shocks.
Depending on your riding style it may be all you need and the savings of approximately $500 over front Elka's to spend on OTHER mods!
Kinggeek
Mandeville,LA
![Quote](images/misc/quote_icon.png) Originally Posted by Bob Denman
Thanks for the review! ![2thumbs](images/smilies/a18.gif)
Can somebody kidnap my Missus, so that i've got some install time to myself??? ![Gaah](images/smilies/gaah.gif)
It only take about an hour!
Kinggeek
Mandeville,LA
OK, I know I already recommended the BajaRon Swaybar as a must have for all RT owners but I just went for another ride today before work and I need to add a little to that recommendation.
I almost feel like I got a new Spyder for the insanely low price of $199 delivered!
I mean every time I make a turn it surprises me how much more stable and confident it feels. I find myself pushing on my outside foot and leaning into turns when I don't really need to any more. I'm not saying it was bad before with the Elka's or even the stocks it is just that much better, VERY NOTICEABLE IMPROVEMENT!
I now see a downside for me, more speeding tickets!
Kinggeek
Mandeville,LA
So, how about some explainations?
When installing the sway bar on an RT does anything factory install get removed/discarded?
How much disassembly is required? From the photos it looks like the Frunk is removed. ![don't know](images/smilies/shrug.gif)
Will it fit with the Spyder Pops Critter Splitter installed?
looks like the bars will not fit the new 2013 bikes??? or will they. Cw dads kid
Cant wait
Mines in the shop for the 6000 mile service. Ron's sway bar came Saturday so I took it to the dealer and am having them install it while everything is apart anyway. They are also wrapping the headers and some of the exhaust in an effort to stop the heat coming through the Corbin fuel door. Just returned from a 1400 mile trip though SoCal, Arizona, Nevada and am looking forward to the new sway bar. The Corbin seat is so comfy.
BajaRon's swaybar
hi I have 2012 rt ron's states the swaybar is for rs not rt. did it fix alright and what did you have to do to make it work on the rt thanks for information. always like to find things to make the ride better.
![Quote](images/misc/quote_icon.png) Originally Posted by DR Buck
OEM bar is removed and replaced with the Custom Performance Sway Bar. Here is a quick synopsis of the process.
You do not have to remove the Frunk on the RT. Removing the Frunk on the RS is much less work and some prefer this method. But it is not necessary to remove the Frunk on either the RS or RT model Spyders for this Custom Sway Bar install.
It is much easier to SHOW the install process with the Frunk removed, so that is why the pictures are presented this way.
On the RT you have to remove the 2 quick release side panels (where you check oil level on the left side and the same panel on the right). This exposes 2 Torx bolts at the rear of the fog light panels that need to be removed. These Fog Light panels are not removed, only the 2 rear bolts on each side.
Then you remove the 2 bolts holding the bottom of the Frunk to the frame. This gives you access to the Sway Bar components.
There are 6 bolts holding the sway bar. Once these are removed/loosend the OEM bar can be removed. The new Custom Sway Bar installs in reverse order. These Custom Bars come with more detailed install instructions.
There is no problem with the SpyderPops Bump Skid and the Custom Sway Bar. They live quite happily together. Harvey would never make a product that would not get along with mine! Nor me his! ![thumbup](images/smilies/thumbup.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by Spacetrucker
The 2013 Spyder sway bar is a different configuration and the current Custom sway bars will not fit them.
![Quote](images/misc/quote_icon.png) Originally Posted by ringalls51
The RS, GS, RS-S sway bars are NOT interchangable with the RT model Spyders. Please do not go there!
However, I carry a Custom Performance Sway Bar specifically designed for each of these respective Spyder models.
![](signaturepics/sigpic963_3.gif)
Here is what you need:So I have completed the install after a few calls to Ron. As stated above you need to loosen the screws holding the see panel. I did not loosen the top frunk screws at all. Also the bolts in the aluminum collar clamps are not metric, they are 5/32. I have included a ink to some photos below that may clarify some things. I am a picture guy!
Start with IMG_001w, IMG_002w etc...... IMG_001w.jpg & IMG_002w.jpg etc.....
Here is link to the install album
http://s808.photobucket.com/albums/z...bar%20install/
Now as for the performance - I havnt had a chance to ride yet! Sorry
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
The BajaRon swaybar is here, it's installed, and it's FANTASTIC!
It came in the mail about noon but I had already removed the old bar so all I had to do was install the new one. I probably spent 3 hours altogether but if I was doing it again, I'd guess maybe an hour and a half. I always learn a lot the first time I do something. The instructions are good but I still have to read them 2 or 3 times to get everything right.
Got it installed and took about a 100 mile test ride, the first half solo and the second half two up with my wife. It handles so much better that it's almost unbelievable. Now my RT handles the way I wanted it to when I got it. It's much flatter and more stable in the corners, especially bumpy corners. There's no juking around if you push it, it just turns. It's really hard to describe how much better it is. I think it helps even more when riding two up but, of course, I won't push things quite as hard with my wife behind me. Still, we were getting through corners much more comfortably and faster than with the old swaybar. She commented that a lot of corners where she would normally lean off to the inside to counter the RT's lean angle, she was no longer leaning. It's better in crosswinds, too. The wind was probably blowing 20 - 25 MPH today and, while I could still feel it, the bike didn't move nearly as much. Tomorrow, I'll try backing the pre-load down from position 4 to 3 and see how that works. Altogether, the best money I've spent on my RT.
Thanks, Ron, you really nailed this thing.
Cotton
I can agree with the 'best money spent' comment. HUGE bang for the buck!
Kinggeek
Mandeville,LA
I changed my pre-load adjustment from position 4 to position 3 and took a short test ride this afternoon. As you would expect the ride is softer and better - but the handling suffers. Cornering is still much better than with the stock swaybar but there is more body roll and it's just not as sharp and controlled in the corners. I'll go back to position 4 tomorrow and may even try at position 5 but I think the best will be position 4.
Cotton
Cotton,
Which year RT do you have, and which shocks?
![Quote](images/misc/quote_icon.png) Originally Posted by bmwlarry
Here is what you need: So I have completed the install after a few calls to Ron. As stated above you need to loosen the screws holding the see panel. I did not loosen the top frunk screws at all. Also the bolts in the aluminum collar clamps are not metric, they are 5/32. I have included a ink to some photos below that may clarify some things. I am a picture guy!
BMWLARRY
Great pictures which I am sure most if not all will find useful - Well done
My question is - in a couple of the pictures the writing of BAJARON on the swaybar is upside down
does this mean the swaybar can be fitted either way up or is there only 1 way and you have it fitted the correct way, Its like the Elka shocks with are fitted differently to the OEM shock with the springs on the Elkas being at the bottom whereas the OEM Shocks have the Springs at the top
Eddie Sheppard
Reading UK
I realized the writing is upside down. With it mounted the other way, the decal doesn't show at all. I looked at it carefully and saw no difference. It seemed to not have any bends that would preclude putting it on "upside down".
There isn't any 'Right Side Up' on the bar. It is symetrical and can be mounted either way.
I realize that the decal will either be upside down, or not visible when mounted. Maybe I should attach them differently. But really, very few people are going to crawl up under a Spyder to see that sticker.
Nice sticker though. A shame to hide it away. I get these from Pete Ameno at PowerSportsWraps (a sponser here at Spyderlovers). Very high quality products and highly recommended for anything graphic that you want to stick to something. They are tough and don't fade like most. I really like that.
You can click on this banner ad link to see samples of what they have.
![Quote](images/misc/quote_icon.png) Originally Posted by BajaRon
![](http://www.spyderlovers.com/adpeeps/uploaded_banners/100000_946149_30.jpg)
Ron
I suspect you would not want to send the stickers out Separately as its a safeguard against someone copying your product and just sticking the sticker on - Fully agree with that
Perhaps you could supply a 2nd sticker for owners to keep - I place any stickers for items iv'e fitted to my Spyder in my service record along with the date and mileage at the time it was fitted, this just gives a complete history of when items were added and the mileage at any various dates
I will be ordering one of your Swaybars for my RT because of the good reports and knowing not only all your
R & D that's gone into it but I have already have a set of your HT Leads and Plugs for my Spyder RT-S SE5 2010 Model which are excellent and have been in use since Jan 2012 mileage was 4,480 when these were fitted my Spyder is now approaching 10,000 miles
I live in the UK so my order will be via an international carrier
The only problem with ordering at this time of year - (Run up to Christmas and the New Year break) esp with International mail - Items suffering from long delays at Customs etc and some go missing altogether
Would it be possible to place an order now for one to be shipped to the UK in early Jan 2013 and if so
How do I reserve one and do you require part payment to ensure one can be held for me or could you hold one for me and Invoice me in early Jan and once payment received you will then send it out
Eddie Sheppard
Reading UK
I just finished the installation of my Baja Ron anti sway bar on my 2012 RT. As others have said, it took about an hour. The instructions with the bar and info/photos on this site make it a very easy project. The frunk was loosened but not removed as suggested.
After a short (30 mile) ride on the local twisty roads after the installation, I could tell that there was a noticeable improvement over my previous handling. I have Elka Stage 1R+ on the front.
In my opinion, the bar swap-out is a very nice change for a reasonable price. I believe most people should notice improved handling. Less leaning, a more stable front end, and better planted to the ground. Which equals more fun to me.
Thanks Ron.
What's next from your bag of tricks? I'm pretty sure I will want it too.
Here are a couple of comparison pictures of the BajaRon bar and stock.
