Page 1 of 3 123 LastLast
Results 1 to 25 of 62
    Very Active Member Laila's Dad's Avatar
    Sep 2012
    Mesquite, TX
    Question spyder is about to be an outside pet...
    I have kept my spyder in the garage since I got it a few weeks ago. The time has come for the spyder to go to the back yard and my f-150 back in the garage. I know I need an outdoor cover. I found one real cheap online for $60. I have a RS-S. I will get the one from can-am if necessary but if I can save $140 then this is what I will go with. Any advice is appreciated. Thanks!
    http://www.amazon.com/Can-Am-Spyder-...=pd_sbs_auto_5
    Aug 2012
    CO
    Tie it down to prevent flapping - which causes scratches on your windshield. Or throw an old cotton bedsheet between the Spyder and the cover.
    JLohPhotos
    2008 GS , Millennium Yellow
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Sep 2012
    Mesquite, TX
    The one from Bike barn looks real nice....but $450
    Dec 2008
    Jacumba, CA
    A bike cover is not the answer. Go to Home Depot or Lowe's and buy a 10 X 12 shed with at least a 10 foot opening. Then your Spyder will be protected from all the elements better than any cover could do. Trying to save a dollar when you spend $18,000 is counter productive.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Aug 2012
    Columbus, NC
    Default Nelson Rigg
    That cover had 0 reviews. DON'T BUY!! Buy the largest cover Nelson Rigg makes, (for a small car) and use it if you want to save money.
    That cheap amazon tarp will be shreds in 1 year. Why does your truck need a garage???
    my Ram 1500 sits outside 365. Its a truck!!
    Put your Spyder back in the garage.
    Aug 2012
    CO
    Quote Originally Posted by Dudley View Post
    I built one of these. .. you need to put it on a concrete slab though.
    JLohPhotos
    If you are going to park the outside, a cover is better than nothing. There are other covers out there that will work besides the more expensive BRP cover--that is your choice of course. I have a BRP cover that came with my original RTS and I have a JC Whitney cover that also works on the other spyder. I like the idea of putting a sheet between the cover and the to prevent scratching in case the cover is blown around. Tying off the cover is also a good idea.
    When I lived in Duluth, MN I had no garage for car or motorcycle. I had one of those storage sheds as mentioned and my motorcycle spent the winters in there. It worked okay for me.
    Aug 2012
    CO
    The drawback of those "cheap" covers is that they don't breathe particularly well. That leads to condensation issues and trapping moisture under the cover. I would stay away if they don't have some sort of vent to let it air out - even in a dry climate. I parked my dirtbike under a cover this summer and noticed visible surface rust forming on the brake rotor; not enough to worry but you could definitely see where it started to oxidize.
    JLohPhotos
    Sep 2012
    Mesquite, TX
    Quote Originally Posted by asp125 View Post
    ...if I had the skill set to build one of these and lay a concrete foundation I would be all over this project...but I don't so I guess I will go with the can-am cover.
    Dec 2008
    Jacumba, CA
    A concrete slab is nice, but not required. Just set it off the ground by a couple of inches on concrete blocks, build a good floor and you're done. And if you are not comfortable doing it yourself, Lowe's or Home Depot have contractors you can use.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    JMHO But you only get what you pay for . I do not have a garage so I bought a Can-Am Spyder cover for my RT . Sure the cover cost a few bucks but very cheap compared to the price of my new spyder. The Can-Am cover has a full soft inner liner to protect the whole bike from cover rash not just the windshield. The sewing and hardware on the cover are top notch and the cover fits snugly and is easy to take on and off. If I was going to trailer the spyder i would snug down the windshield portion of the cover as the cover fits loose here. During the winter months I pay for indoor storage at my dealer. You should buy the Can-Am cover for your spyder RS S
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Laila's Dad View Post
    Here's a cheaper alternative. http://www.menards.com/main/building...72-c-10153.htm
    Active Member Farmbanker's Avatar
    Sep 2012
    Alburnett, Iowa
    Lots of good comments. An alternative that has been used in my neck of the woods is a 10 ft enclosed trailer with a ramp door. Double duty so you can trailer to various places if you want as well. May not be feasible depending on your circumstances but I can get used ones for about $2k around here......
    Red 2016 RTS, Diamond R Armrests, Ram X Mount, Doc Humphreys Dampener, BajaRon Swaybar, Spyderpops "Critter Splitter"
    "It is the common fate of the indolent to see their rights become a prey to the active. The condition upon which God hath given liberty to man is eternal vigilance; which condition if he break, servitude is at once the consequence of his crime and the punishment of his guilt." John Philpot Curran 1790
    Aug 2012
    CO
    Default Yet another option
    Another option. Get an EZ-up with walls. You can close off the front with an add on zippered door.
    JLohPhotos
    Aug 2012
    CO
    Some questions to narrow down the choices:
    - is it exposed to the elements where you intend to park it?
    - are there trees and limbs that could fall/drop onto the Spyder?
    - HOA restrictions as to the enclosure?
    - grass parking or concrete or dirt?
    - likelihood of damaging winds, hail, snow or ice?
    - critters, especially the nesting chewing kind?
    JLohPhotos
    Apr 2011
    GREENVILLE, SC
    Default CHEAP
    CHEAP is, well, CHEAP....
    like the man said... HOME DEPOT, SHED.... duh...
    and get 1 of these: http://www.harborfreight.com/wireles...tem-93068.html
    Jul 2011
    Mount Airy,Ga.
    What ever you do you must keep mice and other rodents away from your RS-S (they like to nest and eat wires) and block it up on wood to keep the tires off the ground. That's IMHO.
    Mike
    May 2009
    Connecticut
    Nothing thats Not Very expensive is going to protect the Spyder like a Sealed Garage?
    I say leave the Truck outside and Be confident the Spyder is Not a Home for Critters ?
    My Ford Sport Trac stays out All Year and we get about 6 Feet of Snow Most winters!
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member Recluze's Avatar
    Jan 2009
    St george, UT
    I have a brand new still in the unopened box cover for an RS that you can have for half of list price plus shipping. Do me a favor and buy it as it is in my way and I will never use it.
    http://bobspyder.wordpress.com/
    #610 2007-2009
    #104 2012....
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Sarge707 View Post
    My truck and Nancy's car have never seen the inside of a garage. That's where the toys live. A truck will weather the storm and inclement weather far better than the Spyder, and it won't be as unhappy about the moisture that accumulates.
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default spyder inside, truck outside
    we have an SS two car garage, my wife's Scion, my Spyder. My truck sits outside, although in a carport that hangs off the side of the garage. the truck doesn't mind.
    it was fun while it lasted.
    Weatherford, Texas
    I live in Texas too. Keep the RSS inside. The F150 will be fine outside.
    Aug 2012
    CO
    I think the obvious solution here, is to simply ......... upgrade to a bigger garage. Perhaps a 3+ car garage.
    JLohPhotos
    Sep 2012
    Port St Lucie, Florida
    I cover my Spyder when it's in the garage, the car and truck stay out side..keep the in side it will never be the same after 6 months outside.
