Results 1 to 13 of 13
    Mar 2011
    Washington, D.C.
    Default Oil leak, a.k.a. "That's just grrrreat."
    So this morning I roll my Spyder out of the bike barn down the driveway. I often have a little oil spotting on the asphalt (go figure). Today, I had a nice big chunk of fresh oil. Hmmm. Still ran the couple of miles to work, figured I'd check it when I got home.
    Once I returned home, I took the tupperware off. Just as I feared-- the oil hose connecting to above the front sprocket was an absolute mess. Just plenty of sludge, grit, and fresh oil dripped down the sides. Joy.
    I went to check the hose fitting to see if the clamp was on tight-- guess what? The clamp split in half under my fingers! WTH? It was like it was cracked, clean break and all, just held on the hose by the sludge. Dunno how something like that could happen-- I'm just glad it didn't fall off down into the sprocket.
    Longtime Spyderlovers may recall I had questions about this before-- I had a little bit of leaking there earlier this year, really just a tad of it near the sprocket.
    http://www.spyderlovers.com/forums/s...I-be-concerned
    Verdict then was this was normal, to be expected. Alas, what I discovered today was anything but.
    Thankfully I caught it when I did, as I subsequently checked my oil level-- and I've got hardly any left .
    While I'm sure that the solution here is pretty easy-- just a new clamp for the hose-- I'm not going to take any chances. I think my belt is coming loose off the *rear* sprocket, a gap is developing there, so I'm just going to drop off the bike at the shop and have them fix the oil hose while I get the belt checked/adjusted.
    The frustrating part? It's supposed to be a nice weekend, I was looking forward to riding the Skyline ride.
    RT-S PE#0027 widowmaker2011's Avatar
    Jan 2010
    Orchard Park NY
    Install new clamp , spray some brake clean on the area to clean it up , top off oil and go ride the skyway. The belt moving away from the lip of the rear sprocket is of no concern unless its now protruding over the outer lip , I've never seen a belt come off for the reason your stating. Go enjoy your ride.
    Back amongst the living May 2021
    2022 RT Limited Hyper Silver
    Out to Pasture:
    2013 ST Limited , Black Currant
    2022 F3L , Dark Edition
    2021 RTL , Chalk Chrome
    2013 RT Limited , Circuit Yellow Metallic
    2008 GS SM5 , Millenium Yellow
    2020 RT Limited Petrol Dark
    2014 RT Limited Champagne Black
    2012 RT Limited White
    2010 Timeless Black RTS SM5
    2010 Orbital Blue RTS SM5
    2008 GS SM5 PE 1941
    2008 GS SM5 PE2011
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by widowmaker2011 View Post
    Default OIL
    So you are saying you were almost totally out of oil.??????.......and the oil WARNING LIGHT never came on.?? What's with that ???????...........Glad you didn't seize your engine........Mike..
    Active Member mooneych's Avatar
    Aug 2010
    South Riding, VA
    Default Oil and Skyline
    Take Scotty's advice and let's go!
    St. Charles, Missouri
    Default Mechanical things do fail--sadly!
    I had a very similar mess happen to my 2003 Vrod HD. While doing the Great Lakes Run some years ago I had an oil change done at HD of Cleveland. Twenty miles out from Cleveland I noticed oil all over the drive belt-sprocket area. Took to another HD dealer and for the small price of $85.00 the loose hose clamp that Cleveland HD left loose was tightened. The bike is long gone as are all but one of my HD's. RT"s forever!
    arntufun
    Guest
    Mike, if you have 4 full quarts of oil in your Spyder it will not show in the stick. When you add the last 1/4 quart thats when the level shows on the stick. I'm sure his Spyder is not anywhere near being out of oil.
    I also agree with the others, buy a 50 cent clamp, add a little oil and ride it. There is supposed to be a small gap on the belt and also agree if it is not near the outside edge of the sprocket, your good to go.
    Default AMOUNT OF OIL
    Quote Originally Posted by arntufun View Post
    Randy, I was just going by what HE said "almost no oil left".....I don't know how he arrived at that ????Mike
    arntufun
    Guest
    Got ya !!!! If four quarts of oil leaked out, the puddle on the ground would spread out and almost be the size of a small car. I hope that was not the case and hope he meant to say it just wasn't registering on the stick.
    Mar 2011
    Washington, D.C.
    Heh... yeah, it just wasn't registering on the stick, that's all.
    But the stick was *dry*, and I had just filled it to the top not 500 miles before. So I definitely lost plenty of oil.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by daveinva View Post
    Hot or cold? It will drop off the stick just sitting overnight. I think you may be over-reacting.
    Default LOST OIL
    But then HE went for a couple of MILE ride, so the oil would be spread on the ground somewhere......with that hose disconected he sure could lose a lot of OIL....The only way we will know for sure is HOW MUCH HE PUT BACK IN...?????????........MIke...
    Default LOST OIL
    So how much did it take to re-fill it..??????????.....So we can end this
