Installing Rear Sport Rack and Backrest on RS-S
So today I installed the rear sport rack. I will start with the good news:
Once you get the sport rack installed, it takes 30 seconds to switch the cover outfor the backrest and visa versa.
Also, I called my local dealership and told them about the 21% off the hondaeastsuperstore.com was offering and asked them if they would price match and they said yes. Rode to Powersports of Greenville and bought the rear sport rack and backrest for $555 plus tax. Oh yeah, they wanted $200 for installation. Yeah Right!!
So this morning I decided to attempt the install by myself. One and a half hours start to finish after making mistakes. Many mistakes. I am now confident that I can do it in 45 minutes max. I used only the tools that came with the Spyder and needed a small Allen wrench that is not in the kit. If anyone is in the area and would like some help installing, ride over here and I will do it for free. And then we can go for a ride in the mountains.
2008 GS.....PE # 2888
Working on my 2011 RS-S SE5 is my favorite hobby. I put on the sports rack and backrest ($547.98), Saddlebag kit ($695.99),1" riser block ($35.99),cliper trim kit ($14.99), and the sport/touring windshield ($129.99) that was the BRP stuff. The best thing I put on was the BajaRon anti-sway bar, that made the handling so much better. I put on led strip stop lights on the back panel, strip lights on both sides, replaced the license plate reflector with one that lights up, the front marker light bulbs with amber led bulbs, and just ordered strip lights for the front fenders in amber/red. On the inside K&N air filter, BajaRon sparkplugs and plug wires, Titanium heat tape, Honda "Y" pipe gaskets, and made a filter to stop the oil from geeting in to the airbox.
Mike
I have a group of friend that I call the fantastic four , two of us are incapacitaded and two are retired. We purchase any part for any of the four spyder and it become an event any day of the week. After installation we have lunch and then for a ryde . We try to do this every week . By the way we have install 4 back rests already.
Mike
Wow you seem to be quite handy with these mods to the RSS. I just got mine and there's alot i want to add on but not sure i have the apptitude for it Ga is not that far maybe I'll take a road trip...LOL I've got the beer if you have the tools.
Backrest parts storage
For all those that have installed the backrest you may want to cut off the plastic flange located under the tail lights. With the backrest installed you can not get to the brake lights to replace them without removing the backrest (at least older generation Spyders). I don't have the link to the instructions but will edit the post when I am to find it.
Also the cavity under the backrest works great to hold a small LED flashlight and replacement fuses and a relay. I was able to hold one of every size fuse wraped in a shop rag to keep them snug and protected.
Agreed! When I did my rack I cut the tabs off the lights while I had it all apart. This is on a 2012. The design hasn't changed at all.
I use the little cubby space for a small first aid kit, small bike lock I use for the helmets, and a small tie down net. Fits in the space pretty good!
Re: Installing Rear Sport Rack and Backrest on RS-S
I installed my backrest/sport rack, and had no idea about the tabs. I'm not quite sure what tabs you are talking about. Pics?
Sent from my SPH-D710 using Tapatalk 2
Here is the link for removing the flange. I removed my plastic flange while it was on the bike.
http://www.spyderlovers.com/forums/s...+light+removal
I installed mine the 2nd week I bought the bike and it was OK. I read somewhere on here before getting into it, that the key thing during the install is patience. Unfortunately, I lack that, so I tried really hard not to lose my cool and yank the whole thing out when I couldn't figure out the proper way to feed the release wire. At the end it all worked out and only took couple of hours. Looks good and functions even better.
