Results 1 to 25 of 30
    Registered User
    Aug 2010
    Enumclaw, WA
    Default VALVE ADJUST, MILES
    Just an FYI for ya all,
    Valve adjustments we find are needed in the 15 to 19k range. Intakes and exhaust both can get tight and we have shimed at least a valve on every full service we have done above 15k. I know there is opinions accross the board on this subject but this is what we are seeing at the shop. Please have someone that cares and knows what thier doing work on your Spyder. To go 30k and not check your valves is crazy and if a shop tells you that go to a new shop. In addition at full service is the time to fix the crankcase breather issue with oil in the air box. With it apart this issue can be fixed at no cost. This fix is being done on 2012+ models at the factory. If you are having issues with oil in air box ask your dealer about it.
    Jeff
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    Quote Originally Posted by SPYDERJEFF View Post
    Jeff
    Jeff,
    Can you explain to those of us with less technical competence why this is important, and what the potential consequences are for not doing it?
    thanks,
    Mark
    I am going to respectfully disagree with you on that. A very competent mechanic is watching his vehicles and I am going by that. I am up to 27,000 miles--but considering it at the end of the year service.
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    Default interval
    so in my Pit Pass I bought with my bike the last service included is teh 15k. with valve adj. since I wound up going to a diff dealer for my 6k oil change, i'm hoping they can do the valve adj at 18k based on what you recommend. the new intervals state when running over 5k rpms > 10% of the time, more like >50-60% for me, that valve adjs should be more frequent. I've increased my shifting rpms and am enjoying much better mileage and wondered as long as i'm changing the oil often, if they really need to be checked more than say every 15k. anyone?
    2014 RT SE6 LTD , White
    Invalid Emails
    May 2011
    Scottsdale, AZ
    I do not see the correlation between changing oil and the valves?? With the poor quality gas we have in the US I am sure the valve seats take a beating and valves are getting tight up there. Like with any performance engine (high rpm) I will get my valves checked around 15000/18000 miles and it should be ok for the rest of the life of the RT!!!
    Sep 2008
    Carmel, In
    Default How long
    How long does a valve check/adjustment take? What can one expect to pay?
    It adds about $600 to the regular oil change/inspect cost. Figure about $800.
    It sure ain't cheap! But in comparison to BMWs...
    I'll take the spyder!
    Feb 2009
    Ceresco, Michigan
    I wonder if dealers are now stocking the shims? It used to be they didn't generally stock them--- so after they got your bike apart and noticed it needed them-- they'd order them....
    Mar 2011
    oregon
    I guess that depends on the model with my boxer BMW you could adjust the valves roadside with the tools under the seat no extra parts in 10 minutes
    Invalid Emails
    Sep 2009
    west Texas
    As long as I had a couple of feeler gauges.
    Cotton
    Registered User
    Aug 2010
    Enumclaw, WA
    Quote Originally Posted by MRH View Post
    Jeff,
    thanks,
    Mark
    Simple as I can, over time the valve lash will begin to tighten up. If this clearance is allowed to become to tight (engine hard turning over is to tight by the way) the valves won't close fully. This then allows the hot combustion gases to blow past the valves and valve seats, burning and eroding the valve and seat faces. The excess heat can damage the valve guides as well. Once these are damaged the valve will no longer seal properly . In the end the valve will fail and loss of compression will occur along with other not so good things. We as a dealer go by BRP's tech schedule even though many people don't. BRP recommends getting them checked at 14k.
    Jul 2011
    Mitchell, Ontario, Canada
    Default Me Too
    Quote Originally Posted by Doc - Riverside View Post
    You mention a fix for the Oil in the Air Box. This is the first time I have seen anything about a cure from BRP. Did I miss something some time ago. From what you said it is a easy fix when the valve cover is removed. Can you be a little more detailed in what is done to make the problem go away. I can't see taking it to the dealer at $150 an hour as my valves are good but still pump oil.
    Surprised no one else picked up on this.
    Doc
    I am also interested in BRP's Fix.
    Jul 2011
    PA
    Jeff
    Jeff, are we talking RT's here as well as RS's? I'd bet most RT's run at lower average rpm's than RS's which would translate into longer intervals for adjustment. Are you seeing the tight valves on RT's?
    I, too, would like more info on the oil/airbox fix. Is this for RT's? They already have a foam filter in the entry to the airbox. But it is not foolproof. I know. Have they come up with something better?
    RT and Gold Wing States & Provinces
    Jul 2011
    PA
    Jeff,
    thanks,
    Mark
    In addition to the explanation Jeff gave, there is another thing going on that can happen before you actually get to the point that the valves are not closing. Camshaft profiles are very carefully determined, not just for the amount of "lift" or total opening but also to control the rate at which the valve is moving throughout its open-and-close cycle. One of the many characteristics in the profile is that when the camshaft is in the position where the valve is just about to settle onto the valve seat, the camshaft profile insures that the valve is set gently on the seat, i.e., the valve is moving more slowly. At the rpm's we're talking here you may laugh at the idea of "gently" setting the valve on the seat but it is true. You can set it down gently or you can slam it into the seat. If the clearance is off too much, then the valve will be set down on the seat at a different point on the camshaft profile, a point where the valve may be moving more rapidly and it will slam into the seat. The eventual effect of this is damaged valves or seats, requiring removal of the head to replace. Not something you ever want to do. Expensive valve adjustments are cheap compared to that. On the other hand, I certainly am not in favor of checking way before needed.
    May 2009
    Connecticut
    Is this something someone could do themselves ONCE they have the airbox off-Even if it takes a week of afternoons OR does it require Yee Ole BUDS just to check?
    Sea Doo GTI-SE 90 Jet Ski!!
    Thinks out loud
    Apr 2012
    Quote Originally Posted by Sarge707 View Post
    It requires one special BRP tool as far as I have heard and you would need the proper shims. Not sure how varied the sizes are. Other than that....having the will, time, and knowhow should do it.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by gypsy_100 View Post
    .....are we talking RT's here as well as RS's? I'd bet most RT's run at lower average rpm's than RS's which would translate into longer intervals for adjustment. Are you seeing the tight valves on RT's?
    The valve inspection/adjustment intevals are the same for both models. They have just been lengthened by BRP, and the first valve check interval delayed from what it was before. Their current recommendation is every 14K...and they have put it in writing.
    May 2008
    Clearwater, FL
    They have just been lengthened by BRP, and the first valve check interval delayed from what it was before...
    ...with 14.28%.
    Jul 2011
    PA
    Thanks, Scotty. I recognize that. I was hoping to hear from Jeff as to whether the tight valves he's seeing are on both models at that mileage or just on the RS's. Practical knowledge versus what it says in the manual.
    Registered User
    Aug 2010
    Enumclaw, WA
    Yes, It's been on both the RS and RT.
    Registered User
    Aug 2010
    Enumclaw, WA
    Doc
    There is an area of the breather system that collects oil. This area is not sealed so once oil collects and fills this space it then blows into the air box. With this area exposed during a full service the non sealed space can be sealed. It will still vent oil gases into the air box and some oil as it should but not the heavy amounts we are seeing sprayed all over the inside of the engine compartment. If your dealer doesn't know about this have them give us a call if they like (360) 825-4502.
    Registered User
    Aug 2010
    Enumclaw, WA
    Thanks for the insight. As far as dealers go around here we are still trying to get them up to speed on the new oil filters.
    Doc
    really? Ok well thats an important thing to get done as we have seen several of the old trans filters imploded apon removal. All the filters have auto updated to new part numbers along with oil change kits so even if they don't know about it they should be getting the new ones.
    trans oil filter with cover part # 219800258
    engine oil filter part # 420956747
    Apr 2012
    Thanks for the elaborations and clarifications.
    I am scheduled to bring in my RT next Monday (8/20/12). I am having the valves checked. I will let you know the results at 28,000 miles.
