Results 1 to 25 of 25
    May 2008
    Tiffin, Iowa
    Question RS Crusie control question
    Ok I really want cruise now and I know Doc McCruise is a hot set-up, however I want to save $$$ on it cause I think this will be the last season for this one. I want a new RS but will wait for a 2012. I will sell it with the cruise so sound off here on suggestions but I'm leaning on Audiovox. So any suggestions are welcome and if kit#'s are available I'm compiling all available data.
    Why am I procrastinating you ask???
    I'm lazy and not looking forward to the install but my numbing hand continues to give me fits.
    I have the throttle lock already but I shave the speed limit so close that could get me in trouble in downhills.
    Jim
    Dec 2009
    West Oz
    If you do a search on Audiovox you will find some answers.
    Mar 2008
    East Dubuque, Il
    Jed go with the audiovox electronic cruise control. I've got it and can help you with installation and settings.
    May 2008
    Tiffin, Iowa
    Quote Originally Posted by dabreitbach View Post
    When you say electronic do you not need vacuum?
    Mar 2008
    East Dubuque, Il
    Yup. The full electronic model. Not vaccum.
    Invalid Emails
    Mar 2008
    Blue Grass, Iowa
    Default cruise control
    I am interested in installing the Audiovox 250-1316 cruise control also. Maybe we can all get together ito install them and have Dabreitbach help set them up.
    Question for Dabreithbach:
    Do you use the magnetic speed sensor or VSS?
    Jul 2010
    kansas ottawa
    when you all get ready to install them come to ottawa kansas and we can all install at the same time ,yeh i need help so come on dowen.
    Mar 2008
    East Dubuque, Il
    Quote Originally Posted by McGone View Post
    magnetic speed sensor and I'll be happy to help.
    Invalid Emails
    Mar 2008
    Blue Grass, Iowa
    Dabreithbach:
    Are these all the parts I need to order? I saw a rubber cover to go over the control pad for $5 on another site. How did you mount your control pad to the Spyder? ITEM DESCRIPTIONQTY EACH TOTAL Audiovox 250-1316 Ultracruise II Universal Electronic Cruise Control Speed Control
    $189.99
    $189.99
    Dash Mount Flat Panel Cruise Control Switch with Engagement Light for Rostra/Audiovox Cruise Control
    $49.90
    $49.90
    VSS Speed Pulse Generator Magnet Kit for Rostra/Audiovox Cruise Control
    $41.99
    $41.99
    I may take you up on the offer of help when I get the parts in.
    Feb 2009
    Ceresco, Michigan
    I too was interested in doing the electronic version of the Audiovox unit.
    A few out here have said they installed them-- but I've yet to see any details or photos of the installs......
    Very Active Member Dochands's Avatar
    Aug 2009
    Oklahoma
    So this electronic version eliminates the vacuum which eliminates the work arounds for the turbo Docdoru needed?
    2022 RT Limited , Carbon black
    Mar 2008
    East Dubuque, Il
    Dabreithbach:
    $189.99
    $189.99
    $49.90
    $49.90
    $41.99
    $41.99
    Yes those are the parts. Check around and you may find some deals on them. I just siliconed the switch and made my own bracket to mount it on the clutch lever housing. Let me know if I can help.
    Invalid Emails
    Mar 2008
    Blue Grass, Iowa
    I have gotten the Audiovox cruise control. Where did you mount the VSS sensor magnet? I have looked on the forum but none of the pictures show the sensor. Is it on the rear wheel inside the belt sprocket?
    Dabreithbach:
    I sent you a PM also.
    Mar 2008
    East Dubuque, Il
    Dabreithbach:
    Never got your pm but you glue it on the outside of the front pully sprocket. The is a bolt above the sprocket that you can mount the pickup on.
    Dec 2009
    West Oz
    Dabreithbach:
    If you follow Lamont's pic and set the dip switches to suit, you don't use the pickup coil and magnets.
    http://www.spyderlovers.com/forums/s...light=audiovox
    Invalid Emails
    Mar 2008
    Blue Grass, Iowa
    I am installing the electronic Audiovox cruise control. The link is talking about a CC100 vacuum cruise control. If you don't use the magnet then what color is the VSS wire. I don't find Lamont's original photos of the install.
    Mar 2008
    East Dubuque, Il
    For the electronic model you have to use the magnetic pickup.
    May 2009
    Appleton, WI
    Its been a while for this post. Has anyone tried this yet? And if so, how's it working for you?
    Invalid Emails
    Mar 2008
    Blue Grass, Iowa
    Default Electronic cruise control
    I installed the Audiovox electronic cruise control with magnetic pickup last summer. Works fine with the settings Dabreithbach provided me.
    May 2008
    Tiffin, Iowa
    Just ordered stuff from your list McGone hope to put it on as soon as it gets here fighting PCV w/Autotune now...
    Jun 2011
    Lynden, WA
    I installed the audiovox on my Suzuki Burgman a year ago. I had to fab some custom brackets but over all it was a relatively easy install. When I took it out for the test run it would not turn on at first so I changed some DIP switch and it worked but, it would not lock in under 60 mph. It took some head scratching but then I realized I had to add more magnets to the wheel. When I did that it worked great. Locked in at 25, and becuase the Burgman was automatic, it stayed locked on through out the gears. I did buy buy a small after market vacuum motor and a vacuum switch to trigger it on and off so it did not run continously. This just allowed my cruise to stay locked on even up long hills when the engine vacuum is less and the vacuum can depletes.
    Good luck.
    Randy
    May 2008
    Tiffin, Iowa
    My cruise control should arrive tomorrow by tracking so friday night will be a late night. anyone looking for something to do friday night there's a party in my garage in tiffin iowa.
    Sent from my Motorola Electrify using Tapatalk
    May 2008
    Clearwater, FL
    Quote Originally Posted by jedd View Post
    Did you mention Party?
    May 2008
    Tiffin, Iowa
    Quote Originally Posted by docdoru View Post
    Sure you show up will get my cruise on it just came.
    May 2008
    Tiffin, Iowa
    Cruise on pcv w/dual auto tune on and working awesome. Thanks to dabreitbach for all the assistance on cruise it is working great could use some tweaking but working fine. PCV is back fixed and maps wrote a big shout out to all at Dynojet for the incredible service on getting a replacement to me!!! The service and obvious desire to get things working right was a very pleasant surprise dynojet gets AAAA+++ from me! See ya'all in Cuba I hope to arrive 1-2a.m. Weds. thats late tuesday night
    Jim
