Page 3 of 3 FirstFirst 123
Results 51 to 74 of 74
Thread: Soar Butt
  1. #51
    Active Member soaring hawk's Avatar
    Feb 2011
    Mankato, Minnesota
    Default natural
    SHEEPSKIN, USED ON BOTH BIKES AMAZING
  2. #52
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    Okay... I just got back from looking at their website; What model or size of these suckers is right for the RTS: both rider and passenger??
    Handle-bars...
    I have the medium seat pad for both front and back and they fit perfect. Here is a link to Amazon that sells them for $84.93 shipped. Just make sure not to put too much air in them. You want to sit "in" them not on them.
    http://www.amazon.com/gp/product/B0045WBVUM
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
  3. #53
    Dec 2010
    Telford, UK
    We have been known to pummel each other's rear cheeks to restore blood circulation. That works great and creates a bit of light relief on a journey. Any on-lookers usually find it amusing.
    The relatively short range we are getting on a full tank provides refuelling stops at about the right intervals for butt restoration/recuperation. I'd like to think this was a chunk of smart thinking on BRP's part. I'd like to think so but I don't.
  4. #54
    The medium cruiser size (14 x 14) fits perfectly on the drivers portion of my Corbin seat. I am still testing it out to see if any improvment. My back was acting up last weekend so only put about 50 miles on my new Airhawk.
    The back and hip problem have been a real issue for me. I have spent a couple thousand dollars to find a seating position I can live with for more that 50 miles at a time.
    I have used the stock seat with a Utopia backrest. The Corbin seat with a backrest. I added seal floorboards so I could move my feet around more. I have used Alaska leather sheepskin pads, Alaska leather sheepskin and gel pads, and now I am working with an Airhawk seat pad.
    Sep 2011
    Waleska, GA
    Thumbs up Seat or cushion
    Quote Originally Posted by Heliplt View Post
    I know people ride farther than I do in a day, butt my butt can only handle about 4 hours in a day, I want to go on some longer trips, butt I need some suggestions or tips to make the stock seat on a RT more comfortable on longer trips, I do have the utopia back rest which is great.
    Having had intense lower back pain for many years and riding during most of the ordeals, I can say that the Utopia is a great start. The Air Hawk is the other 1/2 of your solution. You can get one for less than $200 - the one that fits into the drivers 1/2 of the seat is the one you want. There are 2 or 3 smaller ones, stay away from those. I wouldn't replace the seat until the Air Hawk is tried first. You can use it on a new seat, if that's what you do eventually. It's easy to blow up or let air out of. It looks like a funny shaped egg carton when inflated. I would FedEx mine to you to try out, but I ride every day and I'd be a wreck without it.
    Good luck.
    Tuck
  6. #56
    Jun 2011
    tx
    Alaska Leathers has the large long hair pad in black for 22 bucks on sale just got 2 ordered on a Fir they were here on Tues have used the short hairs in the past butt for the $$ I thought what the hey and they work well keep the heat off your butt and help the all over ride feel better
    The large is 18 x 18
  7. #57
    Sep 2007
    Mesa, AZ
    Quote Originally Posted by Y Rider View Post
    So the Corbin needed some help in the comfort department?
  8. #58
    Oct 2010
    Springfield, MO
    Quote Originally Posted by Rando View Post
    The Corbin fits me great but after about 4 hours I'm done. I can ride about 4 times longer than I could on the stock seat. But if I use the Air Hawk I'm good all day.
    2011 RTL , White
  9. #59
    Jun 2011
    Manhattan, IL
    Default Corbin Seat
    Just installed Corbin seat on my RT. They told me it would take 2000 miles for it to be broken in. Well wife and I headed to Wisconsin to ride through Kettle Moraine State Park since we missed the group ride and wanted to avoid soar butt from the stock seat. After an 8 hour ride we were both able to walk and no soar butt. I am happy with the Corbin seat.
  10. #60
    RT-S PE#783
    Mar 2010
    Illinois Valley in Southern Oregon
    something else that helps . . . . ride often! Just like on a bicycle, your butt gets used to it . . . . we have Corbins on our Spyders, better than stock but not perfect. . . . you can still get the 'barbed wire underwear syndrome' thing going on. . . .
    2010 RS , custom home made billet Red/Black
  11. #61
    Oct 2007
    Default Sore butt
    Get an Air Hawk R cushion. It will make all the difference in the world for you. Here's the web site: http://www.therohostore.com/Departme...-Cushions.aspx
    Enjoy....Paul
  12. #62
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    Quote Originally Posted by paulbrochu View Post
    Enjoy....Paul
    On the RT-limited which sizes would be needed for rider and passenger? I do have the backrest installed also.
    j
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
  13. #63
    Dec 2010
    Tampa, Florida
    Default Airhawk R
    I just got an Airhawk R for my RT-S. Check this site out. I saved $50 and it arrived in 2 days.
    http://www.cli-maxridinggear.com/ser...FQru7QodGUcRQg
  14. #64
    Invalid Emails
    Mar 2011
    NE TN
    Saw Doc - Riverside this past weekend at the Georgia Spyder Riders Meet-and-Eat. I hadn't even gotten my helmet off and he was showing me his Airhawk. Short story, I had been watching this thread previously and wondering about them. Was seriously considering a Corbin or Day Long change of seating. After talking with Doc (who is using an Airhawk on top of his Corbin) I decided to try one. Ordered the AirHawk R and will post more after I have had a few good rides on it. Butt, thus far, I LIKE it.
  15. #65
    Rockin Member Macca's Avatar
    Sep 2011
    Lake Zurich, IL
    I've had my AirHawk R for 3 weeks now and after a 5 hour ride I was glad I bought it. The stock seat on my RT LTD just dosen't do it for me. I've had back problems for many years and I could only ride a hour with the stock seat, as long as I stop every couple hours to gas up and stretch the AirHawk does its job. The key is finding the proper inflation point that suits your backside.
    2011 Pearl White RT Limited
    HMT Brake Light, Fender Tips Kit, Mudflap Lights, GloRyders, Seal Floorboards, Powerlet 12V, Garage Door Momentary Button, Bump Skid, Elka's Stage 1, Ultimate Sea, Air Wings
    Member of the Woodstock Spyder Ryders (Illinois)
  16. #66
    Nov 2010
    Norway, IL.
    Soar butts fly, sore butts ache
  17. #67
    Mod Monster Phil's Avatar
    Nov 2010
    Tyler, Texas
    Quote Originally Posted by Doug B View Post
    I was wondering when someone would point that out
    Sent from my iPhone7 using Tapatalk
    ____________________________
    Phil - Tyler Texas
    2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
  18. #68
    I am guessing that most decided to give the poster a break. Even I spel thing wromg sometime.
    Oct 2011
    dunnellon fl
    Default airhawk
    buy it. it's worth every penny. i got over 100,000 on my first one before i had to shoot it. i still couldn't put it in the dumpster so i left it for someone else to do the deed.
    buy
    I'm good for a couple of hours behind the bars before my bottom starts to mutiny... I guess that I'm going to have to look at these Airhawk thingies to see if that'll help keep everybody happy... Thanks!
  20. #70
    Jul 2010
    Pittsburgh, PA
    Quote Originally Posted by eightballbob View Post
    buy
    +1 on the airhawks. get the original or the newest version not the cheaper version 2.
  21. #71
    On the more expensive side of fixes...
    How about a Corbin with the Lamonster cut?? Has anybody else tried this one??
  22. #72
    Very Active Member Star Cruiser's Avatar
    Jan 2008
    Wasaga Beach, Ontario
    I had the AirHawk rectangular seat and it was great. I bought the Airhawk R a few months ago and it is AMAZING. I would recommend it in a heartbeat.
  23. #73
    Default SEAT
    As has been mentioned bike shorts work great , they are designed to wick moisture and generally avoid poorly placed seams, Trunk style long leg boxers actually work well for shorter rides ... also look at JCWHITNEY .COM they sell fairly inexpensive gel pads covered and non-covered. Mike
  24. #74
    Jan 2008
    Quote Originally Posted by daveinva View Post
    Good luck with your Airhawk, Alaska... as I said, I bought the new R version (with the risers and floorboards I was putting a lot of pressure straight down, the middle gap on the R appealed to me and so far it seems to help).
    The one thing I sorta dislike about the Airhawk, at least the new R, is that with my Ultimate Seat it's not really wide enough to cover the whole width of the seat, so I end up being a little "perched" even with the cushion deflated to the lowest workable level.
    That said, the nice thing about the perch is it lets me use my otherwise unusable Rivco highway pegs (I love the floorboards, but those pegs are waaay too close and up high to be of use... thinking of switching out the mounts with KM or ESI, $$$ grrrr).
    Last thing: I've heard of people using a sheepskin *over* their Airhawk... I think I might try that.
    Be sure not to over inflate the AirHawk. It will feel like being perched & a bit like floating on top. I inflate mine, sit on it and open the valve to expel all of the air & then give it 2 short puffs of air. Works great for me. I did the same for both my Original AirHawk and the R
