MOgang Member & Monster Member
I am going to do it
I am going to find Lamonts post on drilling the key and i am going to put a hole in mine for a key ring.
I probably wouldn't have done it, but I went to purchase a new garage door opener today. I typically keep the RT in my shop and I have a single button remote for that, but when my son is off to college, I use the third bay of the garage. So I was stealing the remote from my truck and then having to remember to put it back. So, I went today to purchase a new 3 button remote for the RT on a permanent basis.
Found out the coolest thing. My dealer now stocks the mini 3 button that is about the size of a fold over match book! Has a place for a keyring and everything! I wish the spyder key did too. . .
Oh well, I am always game to try new things. I just hope I don't cost myself a hundred plus bucks in the attempt!
I am wishing good luck to myself. That is legal. Right?
When we were at the BRP Owner's Event in Maggie Valley we were told a hole is not placed in the Spyder key for a reason...they don't recommend extra weight be placed on the ignition switch by having things hanging from a key ring. Just passing on what we were told. We had to have our ignition switch and module replaced earlier this year when we couldn't get the trunk or seat release to work. (Erags has since removed the seat lock from our bike). That problem has only occurred in 3 bikes in the world (including ours)...aren't we special? LOL.
Key Fob for Garage Door
UOTE=SteveMac;367433]I am going to find Lamonts post on drilling the key and i am going to put a hole in mine for a key ring.
I am wishing good luck to myself. That is legal. Right?[/QUOTE]
It works - very easy. I drilled a starter hole with a very small bit - in case there was resistance or I slipped. I then re-drilled with a bit that was bigger. I started the small pilot hole right at the ridge of the raised black rubber - if you error do so toward the center of the key (a bit) otherwise the area left at the top will be very thin (where you put the key ring). Held the key with my foot on a piece of wood - did not want to put it in a vice grip (did not want to damage the key:-)). Having seen the picture (thank you, Lamont) of the open key I was very comfortable doing this. I have the small very very light garage fob attached to the Can Am key, it does not seem to rub at all. I can open my garage as I am coming down the street. Sweet!
That is very strange. I've been running a Billet Aluminum Key Cover on my Spyder for a few years with no issues. There are probably a few hundred others doing the same thing and I have not heard of any issues with the additional weight.
Maybe because it is centered and balanced.
That does kinda make you wish you had the same luck playing lotto! The FOB is very light so I don't think weight will be an issue. I am more concerned about not destroying the chip in the key.
We had to have our ignition switch and module replaced earlier this year ... That problem has only occurred in 3 bikes in the world (including ours)...aren't we special? LOL.
Make me #4
My ignition switch doesn't work either! hahahahahah
I figured you would laugh at this picture. I wonder where the other half of my key is, lol
Originally Posted by Motavar
Make me #4
I don't know where the other half of the key is ... but if it ever gets found and returned to you, I would drill a hole in it and where it as a reminder of your good fortune and the fact that you survived your accident.
If my feeble memory serves me correctly... I believe that the chip is pretty much located under the "N" and the Hyphen, beneath "Can-Am". If you put the hole on the outboard side of the C or the m, you should be ok... BUT PLEASE check with Lamont before believng me!!!!
Don't steer me wrong now Bob!!
LOL
Don't worry. I'll check Lamonts post carefully. These keys are PRICEY! unlike the other less expensive parts for the SpYder . . .
Key cover
I have been thinking of a different approach to attach a ring to the key.
Perhaps a molded or Machined case to enclose the chip end with a small hole to allow for a house or car key to be attached. Thus no drilling or possible chip damage. Scabbard is OK but I keep thinking the key will slip out and I won't notice it's gone until I need it.
Originally Posted by SteveMac
LOL
No guts no glory ; People have been drilling those keys [successfully] since the spyder first came out.
X-Ray'd Key
Here's the post on SpyderTalk where someone X-Ray'd their key (post #18)
http://www.spydertalk.com/forums/topic/11676-key/
SpyderLovers Founder
Not to hijack the thread,
But the original post was regarding options for a garage door opener.
I keep mine in my glove compartment attached with velcro
I would recommend this or something similar. I know others have successfully drilled the key but if BRP doesn't support it, it's probably a suboptimal idea.
IBA #47122
2020 RT Limited Asphalt Grey
Originally Posted by Lamonster
Thanks Lamont!
Saves me some searching!
I hear you. But here is my thought. I fish around in my pocket like crazy sometimes looking for that one key. People look at me funny and mothers hide their daughters eyes like I'm a perv! Seriously tho attaching the garage door FOB will help me a lot. It bugs me having to flip up the glove box lid when I am rolling up to the garage (or out). Trivial I know. But i have pinched my Dockers in the box lid before on my way to work. Yuck.
But I am sure I will like it when done.
Originally Posted by Mexican
There you go ,,it works perfectly fine,,
Excellent. Thanks for the pic!
A successful surgery!
TaDa!!!
Hey, that is one good looking key modification
