Results 1 to 24 of 24
    Apr 2011
    Charleston, SC
    Default Avoiding obstacles
    My husband was ryding my spyder the other day and saw roadkill right in the middle of the road. He missed it with the front tires but hit it with the back. His question (and mine) are this: Which is the better tires to hit an obstacle with - the front or the back? His idea is to hit it with the back as it's the bigger tire and you prob wouldn't lose control. Thanks for any info.
    Invalid Emails
    Feb 2011
    Converse, Texas
    Generally I'd have to agree that it is better to hit an obstacle with the back tire if it could not be avoided altogether.
    Dec 2010
    Fountain Inn,SC
    We are talking about possums, rabbits and such.When you can't avoid it My thinking is try to miss it with the inside of the front tire and the outside of the rear tire. I have done this and at other times I hit it with the back tire. O well Hope i don't see anything bigger because it will be Ketty bar the doors if it is anything bigger
    MOgang Member & Monster Member
    Mar 2011
    Jackson, Missouri
    Quote Originally Posted by fispyder View Post
    Bingo!! Just miss on the inside of the front tire and outside of the back. That is the method I use also. Now, if it were just that easy with the water puddles....boy, those get sketchy sometimes.
    Banged Up Member
    Dec 2009
    Sanford, Florida
    This issue is one of those that reminds me that I have aged. Although I'm pretty quick, I just don't have it like I did say thirty years ago. I think the operative word is "try" to avoid or "try to" miss with both, but saying and doing at my age are sometimes oxymoronic.
    Chris PE# 0004
    The third wheel in the middle has also been an issue for me. I have hit a few things in the road squarely with the back wheel. Now, I try to avoid things by just edging them with either front--if possible--it does not always work though. Looking ahead as much as possible is the best solution, but that does work all the time either.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Hey, wait 'til you tow a trailer, and add two more tracks. It's like trying to avoid an obstacle with a steam roller.
    May 2008
    Tiffin, Iowa
    +1
    Missing with the Inside front and outside rear wheels is about the best attempt that you can make... IFF.. the ex-critter has been turned so that it's lying parallel to the direction of travel! Beyond that of course all bets are off, so slow down and grit your teeth...
    Scotty, How much does the trailer hinder any emergency maneurving??
    May 2008
    Saratoga Springs, NY
    http://www.flickr.com/photos/2772998...in/photostream
    M
    My experience has been that you don't even notice the trailer. If anything, it may actually stabilize the a bit in emergency or abrupt maneuvers.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by mike3069 View Post
    It does make it impossible to miss an object by taking it just inside the Spyder's front wheel, though. On the other hand, the independent suspension of the RT-622 soaks up the divots like a sponge.
    Invalid Emails
    Apr 2008
    Orange Park, Florida
    Something happen to me awhile back.... A Turtle of all things.... There were people on the side of the road and of course I didn't know what the heck these people was gonna do, my luck jump in front of me and hope I stop to tell em all about the spyder. My mind was watching them. As I gotten closer saw the Big Snapping Turtle in the middle of the road, started to turn to the left side unfortunely I couldn't due to a Car headin' toward me. Can't go to the right because of the people. The turtle went right under me, boy scared the crap out of me not only the rear tire hit him but shot him twenty to thirty feet back in front of me. Stop the turtle was still alive picked him up took him, and was the first time able to pick up a snapping turtle with him snapping at me! to the wood next to the road and off he went. And Remember the people.... Well I got yelled at by em didn't you see the f.... Turtle, want to say well if you weren't standing on the side of the road I might have! well if its turtle brace yourself for some rude awakening!
    Spyderless Member
    Dec 2008
    north/central n.j.
    I've nailed a few Squirrels especially when they run in front of the Spyder and try to straddle the front tires,
    The rear tire gets them every time.
    Banged Up Member
    Dec 2009
    Sanford, Florida
    Quote Originally Posted by Cundiffla View Post
    At least they were standing on the side of the road. I've seen times where they stop their car in heavy traffic, get out and try to replace the turtle (in these cases it was usually a gopher) all the time traffic is about to run them over.
    Chris PE# 0004
    Jul 2010
    Pittsburgh, PA
    if no one behind you best bet is to hit the brakes hard use the ABS of the spyder and hope you can get enough time for approaching car to pass and then swerve to miss the turtle (assuming no other cars after that one coming at ya and no one behind you to rear end you).
    Brake it right to the limit... If your oncoming traffic clears you you'll have more room to show off your dance moves...
    RT-S PE#0311
    Oct 2009
    Orlando, FL
    When at this past 2011 Spyderfest Cuba, MO, it was turtle road crossing day when Blinc and I finished our Passport Run. Had 2 of them crossing the road in front of me. Was able to avoid 1 of the 2 and although they were quite small, there was not enough clearance to miss the second. Sadly he never made it to the back wheel. It wasn't the outcome I was hoping for.
    Invalid Emails
    May 2009
    Clearwater Florida and Frankin NC
    Quote Originally Posted by Wheeler~ View Post
    Rumors have it that was the new Missouri radar turtle. They have been testing them on backroads. Anyone have first hand proof that they work????
    Sent from my DROIDX using Tapatalk
    Senile Member M2Wild's Avatar
    Dec 2008
    Ellington, CT and Sandy Creek, NY
    Spyder doesn't have a lot of clearance. So going around the object is preferrable. For smaller stuff, front wheels soaks up the bumps much better than rear. For bigger stuff, rear wheel hits are safer (provided that you lift ur butt off the seat so the impact doesn't buck you off).
    Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
    Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
    Boerne, TX
    I have noticed it is easier to miss a _______ on my Motor Trike than on BR1 due to the more narrow front tire on the Wing. It is better to hit a ______ with the back tire so "stuff" does not fly all over your plastic....hitting them with the front tire makes them squirt sometimes... JMHO
    RT-S PE#0311
    Oct 2009
    Orlando, FL
    Quote Originally Posted by dave01 View Post
    $247 later, I may be able to attest to how it works. Now I may be glad I took one of those turt's out! Almost like my civic duty.
    Quote Originally Posted by BIG RED 1 View Post
    BR; You just made my appetite head for the high ground...
    Jun 2010
    Las Vegas
    No, silly it was the Remote Spyderfest Video Turtle. We encountered them on the Ladies Ride positioned in the middle of the lane and panning with its camera lens from side to side to get a good shot of us passing.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    RT-S PE#0311
    Oct 2009
    Orlando, FL
    Oops, I stand corrected!
