SaddleBag/TB duel exhaust clearence.
If you ever wondered if Givi V35 saddle bags (Brp R35 bags are the same bags with BRP logo stamped on it) would clear Twos Brothers duel exhaust..Here you go.
Also if you buy the Givi V35 bags..they're cheaper then if you buy from brp. AND....the Color trim panels from BRP will fit on the Givi V35 as you can see from the pics. =D
Looks nice. What are you using for rear blinkers?
While the brp setup is a bit more - the quick release racks are worth it IMO.
These are also the Quarter-turn/single button quick release. They are exactly the same as the BRP R-35
pic
Can't tell from those pics--- so you're saying the RACKS come off with the quarter-turn quick release?
Where's your rear blinkers then??
See where the BRP ones put the blinkers.....
Here's the BRP ones:
Rack ON:
http://www.spyderlovers.com/forums/a...3&d=1243951727
Rack OFF:
http://www.spyderlovers.com/forums/a...8&d=1243951858
Rack and bag removed -- 30 seconds:
http://www.spyderlovers.com/forums/a...2&d=1243951921
Blazing Member
Sweet set up with the Corbin Smugglers trunk and the Carbon fiber rear fender .
Originally Posted by sledhead
I was reading your replies wrong. The bags are remove-able but the racks are not. I wonder if the the BRP racks would clear the duel exhaust? But the panels are universal fit
Mounting Kit Used?
I purchased the BRP saddlebags and mounting hardware and installed them. My bag is hitting my Two Brothers exhaust and it looks much lower than yours. I have the quick release frames that came with the bags. Please advise if you did modifications or have a different model of the frames.
MOgang Member
Heard of someone lowering the upsweep the the pipe...
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
see this is enlightening to me simply because now i know i can buy the saddlebag liners for the givi and be good to go on this bike
its funny because two brothers specifically states that the dual will not work with the luggage. good to know, because i wanted to get these... thanks for this!
Height
Your saddle bags are sitting a lot higher than the BRP oem setup and that is why you can fit the TBR twin exhaust.
The TBR website says that the dual/twin system "will not work with factory luggage". That's why I opted for the single canister.
2013-can-am-spyder-st-limited-for-comfort-touring_2.jpgTBR slip on carbon canister.jpg
Originally Posted by NZSpyderRyder
yeah i was just looking again at his pictures... his saddlebags sit 2-3" higher than the brp version. so... guess i'll go with the single as originally planned
Can you post the part numbers or sku for the bags and the mounting bracket you used? Also where you found the best price on them. Thanks.
Tags for this Thread
