Clock doesn't keep time
The warranty on my wife's 2008 Spyder is nearly over, so I was trying to think of anything that should be taken care of. The clock has always been terrible at keeping time. It gets off by about 5-10 minutes each month. Is this a common problem to Spyders or should I try to get it fixed under warranty?
Thanks,
Bruce
Yorktown, VA
is load bad battery
take to dealer and let test with bud
great feed back with pictures
Thanks,
Bruce
Yorktown, VA
Same here, mines an 08 too. Been that way since new.
But I'm Retired so i don't care if the clock is off ,when i get there i get there.
Mine has never in its 1.5 years kept accurate time, and its not a low battery in my case.
The clock on my 08 SM5 is always wrong as well...BUT...at least it GAINS time, so I'm never late because of it!
They all seem to do it. Reset it once in a while, and all will be right. It is not a big deal.
Registered User
Have not heard of any slow clock Spyders. All seem to be fast. I reset when it gets more than 10 minutes fast. Must be the US/CAN time exchange rate.
When they build consoles with a new lot of crystals then they may all run slow
+1
Happy owner of Silver PE #1232
All The Gear All The Time - ATGATT
Gulf Coast SpyderRyders
My brother's $125000. bimmer does that too,Brp is not alone there.I wouldn't bother with it. Reset....done.
Got tired of resetting the clock...not sure it's still there, haven't looked lately.
john
have never set mine since new so i don't know if it works or not. I would have to guess no because the time is not right.
Originally Posted by musicarcade
Believe me, I know!
Crossing my finger and toes, throwing salt over my shoulder,
that my behaves, and hopefully when I get to Tenn. there *might* be a competent tech to check out the "check transmission" issues I'm having (more often than not) with my paddle shifter.
Sorry to hijack this thread..
...anyone know what time it is?
I hear you loud and clear! I do believe it is Yuengling time!
Very Helpful Member
+18 or so. My clock runs too fast by about 10 minutes per month also.
Former Happy Spyder Owner
Just decided it was time to move onto other things.
SpyderLovers Sponsor
Originally Posted by BajaRon
AHHHHhhhh.... Be Still My Heart! Something doesn't work right and it gets a pass by Scotty!
Somebody quick! Take his temperature! Something is bad wrong here.
Did somebody hijack his SpyderLover's login and is posting without his permission?
Mine runs fast too.... Always has.
My RTS is teaching me tolerance, Master.
Mine increases 5 minutes for each person that asks HOW fast dose it Go! Looking at the display
I also found that the digital speedometer is faster than the stick one...however, whenever the bike is serviced (and an update is done), they zero out for a while again...then, with time, they differ by a few mph.
The zumo also shows slower than the digital...
