Results 1 to 25 of 29
    Registered Users the nicko's Avatar
    Jul 2009
    sweden Luleå
    Default Drive belt tension
    DRIVE BELT TENSION TOOL TO CAN AM SPYDER 09
    What is best belt tension tool i can have
    great feed back with pictures
    May 2009
    Venezuela
    Default Krikit II
    Quote Originally Posted by the nicko View Post
    I just used this Krikit II to correct the tension on my SE5 as per the new bulletin 2010-6 Drive Belt Tension Specification... (+/- 120 lbs.)
    Make sure you get the one with the little "winglets" on the sides, which is specifically for flat belts. They have another one without those winglets with an edge to be used for V belts.
    Saludos, Pilo
    Jul 2009
    sweden Luleå
    thanks look for one the net
    Very Active Member ArmyJoe's Avatar
    Jul 2009
    Columbus, Ohio
    This is the one listed in the service manual:
    http://www.gates.com/brochure.cfm?br...cation_id=3539
    but they retail for $800.
    2009 Yellow SM5 with BRP R35 saddlebags, CHAD windshield, ESI Up & Out Mirror Extensions, ESI 4" Handlebar Risers, Hindle muffler, Green Filter, Juice Box Pro, Throttlemeister, Crampbuster, Cortech Sport Tailbag, trunk liner, trunk spring, 12V trunk outlet, Eastern Beaver PC8 Fuse Panel, and two dashboard Powerlet outlets.
    Certified Huligan
    The user formerly known as GIJoe
    Alignment Specialist
    Aug 2008
    MD
    Why not have the dealer do it for you so you don't have to buy the tool?...other than this one time you'll have to adjust it, will you have another need for this tool?
    May 2009
    Venezuela
    Default Sweden Dealerships...?
    Quote Originally Posted by bone crusher View Post
    I am not sure that there will be such a tool in a Sweden dealer, especially taking in consideration the price of the tool and the quantity of Spyders in the country.
    Bought my Krikit II for less than US$15 and taught my mechanic how to use it on my SE5, since he has the torque wrench and socket for the rear axle nut (and I don't).
    Those of us that reside in countries other than USA and Canada, and want to enjoy Spyder riding, sometimes have to make do with what we find...
    Saludos, Pilo
    Jul 2009
    sweden Luleå
    take ride to dealer see if he has one
    or get ride mc shop i be back with it new information soon
    thanks for help
    Jul 2009
    sweden Luleå
    Gates 91132 Belt Tension Tester cannot be shipped to the selected address hahaha
    Aug 2008
    MD
    Quote Originally Posted by Pilo View Post
    Saludos, Pilo
    Are you in Venezuela or Sweden? Either way, I guess if you don't have a dealer around, it doesn't make a difference...gotta do what ya have to! Perhaps you should open up a Spyder dealer? Now, that would be cool!!!!
    May 2009
    Venezuela
    Default Venezuela
    I am in Venezuela, and there is only one BRP dealership about 500 miles from where I live, and they don't carry the Spyder line.
    I bought mine in USA and had it imported into Venezuela, along with some filters and spark plugs; just basic maintenance items.
    I have to assume that there are just a few Spyder dealers in Sweden, and not many would be willing to invest nearly US$1000 in a gadget that is going to be seldom used.
    Of course, that's just my opinion. I could be wrong... (like Dennis Miller used to say)
    Let's hear what the nicko has to say about BRP (Spyder) dealers and service in Sweden...
    Saludos, JMD
    Motorbike Professor
    Mar 2008
    Allegan, MI
    The reduced belt tension spec has made it a bit easier to get the belt right. After dealer adjustment to the revised spec, I found the old standard of being able to give the belt 1/4 twist at the center between the sprockets, using just your thumb and forefinger, holds true now. before you could not come close to this. This is done with the Spyder on the ground...and should get you mighty close.
    Aug 2008
    MD
    Saludos, JMD
    Es my interesante. Para seguro, Venequela es un lugar que is diferente de Los EEUU. Es lastima que Chavez es una cretura del Mar! Espero que puede obtener todo que necesita para tu Spyder...la verdad, para seguro, es que es mucho mas facil recibir ayuda aqui. Buena suerte con todo!
    Jul 2009
    sweden Luleå
    have seller in my town for brp and engineering mechanics , nice that
    mechanic my town very good
    in my country have all way down land brp seller an mechanics
    three town from my main headquarter town callad umeå fore can am spyder self locate in luleå not big country but i have spyder
    in sweden bra och ha om de går dåligt
    nice to have when goes wrong link www.vaplan.com sweden map
    May 2009
    Venezuela
    Default Indeed...
    I agree that chavez is an evil creature, and is pushing this country into communism and into oblivion as well...
    I came to this country 30+ years ago when it had a bright and promising future; that is not the case now, not anymore.
    I am planning to move back to my country (Argentina) and resettle there with my Venezuelan family.
    Of course I will be taking the Spyder with me.
    Regrettable, down there I will have to pay around US$25 for a tank of gas for the SE5, while here I can do it for less than US$0,25...
    Saludos, Pilo
    Very Helpful Member bjt's Avatar
    Oct 2007
    Grand Blanc, MI
    ... Regrettable, down there I will have to pay around US$25 for a tank of gas for the SE5, while here I can do it for less than US$0,25...
    Saludos, Pilo
    I was in Maracaibo a couple of years ago. I don't remember the exact price but I do remember it was very cheap. I remember passing through the security check points on the roads and seeing hundreds of confiscated containers (gas cans, plastic bottles, jugs, etc.) of gasoline that people were trying to smuggle out.
    Former Happy Spyder Owner
    Just decided it was time to move onto other things.
    May 2009
    Venezuela
    Quote Originally Posted by bjt View Post
    It is still happening in the border towns and nearby cities.
    It gets smuggled into Colombia for a huge profit, and it is sold to riders and drivers at prices lower than those posted in Colombia.
    The government is trying hard to control that sumuggling in the border areas, with limited success.
    Saludos, Pilo
    Jun 2010
    Sanger, California
    I just had my belt adjusted by the dealer (free) and it can be turned 1/4 by my thumb and forefinger as you stated.
    Jul 2010
    Huntsville, Al
    Default tension
    Scotty, how easily should you be able to twist the belt? On my RT, I can twist it 90º, but it takes some effort.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by sinkhole View Post
    That's right. It shouldn't be real easy.
    May 2009
    Connecticut
    Since my belt was lowered from 1150 Ketons to 600 ketons I can twist it 90 degrees with some effort. BUT , it makes MORE noise when I accelerate fast, almosts like a flapping sound. Is this OK?
    Sea Doo GTI-SE 90 Jet Ski!!
    Oct 2007
    Grand Blanc, MI
    +1 If it was easy, it could twist more than 90.
    Sep 2008
    TX
    the nicko - I imagine you're riding 24/7 during mid-summer up there near the Arctic Circle!!
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Jul 2009
    sweden Luleå
    Yes riding bike long time now pauly1
    United States
    Default drive belt tension on 2014 spyder rt
    I have a 2014 spyder rt. i been looking for help with the drive belt tension adjustment ideas. i decided to try some ideas from my harley-davidson days.
    this is how i adjust my drive belt on this spyder. first i made sure that the belt tension was set with my kirkit gauge. then i loosen the axle bolt and nut, now i jack up the spyder and block the front wheels. then i started it up and put it in first gear and let it run. as i said i had set the belt tension already, my belt was running to the left outside of the rear wheel sprocket. i then started to adjust the right side to get the belt to rub the inside of the sprocket, very touchy. then with the spyder still jack up and running, i started to tighten the axle nut and bolt, as i'm doing this, the belt is moving out to the left side of the sprocket and not staying align where i wanted it. back to loosen it up again, and doing more adjustment to the right side only, then tighten the nut and bolt again. did this till i was happy with the belt position. then i lower it down and took it for a test ride, about ten miles, stopping during the test ride to check the belt alignment, stayed where it was suppose to be. hope this can be of help to other.
    Active Member greybeard's Avatar
    May 2013
    indianapolis indiana
    my dealer had no idea what a cricket was and didn't want to use it. when he put a new tire on the rear he set it to 700 on their sonic gauge was tight as a banjo string and now 3000 miles later when he replaced the front drive pulley I asked him to not set it so tight, so he set it at 400. when I checked it with the cricket it was 210 pounds. At 700 on the sonic gauge would have been over max on the kricket
