Results 1 to 14 of 14
    Invalid Emails
    Mar 2009
    Macungie, PA
    Default GloRyder install
    Is there a way to put the GloRyders on without removing the wheels? Just got mine and need to install.
    take the center hubs out of the wheels and put the inner ring in that way. The workspace is tight and you will get about an 1/8th turn on the allen wrench with each try---but the ring eventually gets tourqued down. Its just as bad to take the wheels off and do it from the back side. Same issue--you get about 1/8th turn on the allen wrench. Ive done it both ways and prefer not jacking up the bike and taking the wheels off. The work is worth it though--the GloRyders look great. Purple on the red bike, orange on the black bike.
    western Colorado
    Quote Originally Posted by Dukester View Post
    Good Question! I just Ordered A Yellow Set and asked when I made the purchase. They said it is easier to do with the wheel mounted because there is not much room for the bolts. Just have to be place something between Screwdriver & center cover.
    What color did you happen to get by the way?
    Aug 2008
    Mashpee Mass,02649
    yes take center hub cover off put the ring in tighten it and make sure the ring is on the ring inside then put cove on two nuts then guts cover and have fun...
    I have green on my spyder................going to Laconia in 7 days and counting lol
    Alignment Specialist
    Aug 2008
    MD
    It is not an easy install as you are effectively pinning the three screws into the metal...you have to go slowly with each screw...and tighten a bit and move to the next, etc...or else you'll push the thing off.
    I could swear that the thing was gonna gome off with one good bump but it appears to be staying just fine. Also, rotate the tire with each screw tightening...it will give you a better approach to the screws...take your time and don't get frustrated...it is not easy to do and if you rush, you'll have to start over again...
    Once on, they do a great job...I was out at night and stood over the bike to see the outside rim...sweet!
    I have the yellow too...they look great!
    Active Member SocalT's Avatar
    May 2010
    San Diego
    Default Paitence
    Takes a little time, but fairly easy install.
    Blue is the color on mine
    Facta Non Verba
    2010 RT-S SE5 PE 368
    Invalid Emails
    Mar 2009
    Macungie, PA
    Default GloRyder
    I have yellow. Took wheels off to do the job. I will test them out tonight. Thanks for all the advice.
    Apr 2010
    Milehigh City
    I like them.
    May 2008
    Kingsport TN
    Default GloRyders
    We have over 6700 miles on ours, they do not come lose, and have never had any problems, only good comments from those who see them, would like to have a remote for them, keep up the good work,KURT.
    May 2008
    Raleigh, NC
    I took my wheels off to put them on..not a big deal at all. Easy mod. I too wish I had a remote..I have blue and not always in an area that is "blue" friend with the local Leos'.
    Aug 2008
    MD
    Quote Originally Posted by Extracool View Post
    I love mine...you have to admit that there's that inkling of thought that they might come off with a big bump...but they don't! I have yellow and think they look great! I recommend them...
    western Colorado
    Just a Quck Note to Kurt at Gloryder. He set me up with a Nice Set Of Yellow gloryders. Got them in the mail on Saturday & installed on my 6 spoke rims yesterday. Took a Evening ride just to check them out. "Sweet" Thxs
    Jun 2010
    Winnipeg,Canada
    What is the loudest color??? Anyone seen the different colors on the road?
    Jul 2009
    Union Country, NJ
    Default Glowlights
    I put mine on without taking the wheels off and they have been on a year without any problems. If you are in the north, like me, I would recommend taking out the electronics, removing the batteries and storing them in the winter to keep them from oxidizing or the battery leaking if you keep your spyder outside or in an unheated garage in the winter.
