Cheesy airbox 2.0
Since many have asked if my vents are 'real' and wanted to know what is under the hood.... here it is....
This is my "cheesy airbox 2.0" prototype.
Been running this one for around 3,000 miles and seems to work very well at keeping the Evoluzione intake noise quiet while bringing in cold air for the intake. Both vents feed cool air into the new airbox-- which is simply 2 parts held together with zip-ties (hey-- I did say CHEESY didn't I).
My main goal was to quiet things down as the Evoluzione intake setup is LOUD! This cut noise down easily 50%-- probably closer to 75%-- I can hear my Hindle again!
Inside the box is the Evoluzione Race intake foam filter/manifold plate.
I used:
3" Fresh Air duct rated up to 400 degrees
2 Stainless steel marine cowl vents
2 Intake Duct Mounting plates
DEI Heat Shield and heat tape.
The entire box was made by using the sticky-back DEI heatshield-- 2 layers stuck to each other. I had leftovers so I used that on the Y panel. This stuff is amazing--- REALLY sticky, fireproof, heat shield.
Still hoping someone will come out with a new airbox setup.. or might go with an Aerocharger setup... but for now this is my current airbox prototype.
Any questions or ideas--- post away.....
Very cool work, I like it. Have you compared running it without the intake hose's? I've noticed in previous projects very much ducting of intake air creates too much turbulence in some cases. Just try it with out tubing let the hot air in see if you are leaner if you are leaner without tubing then tubing is too restrictive. This is just a test I would do if it were mine.
Very cool
Jim
Nice write up Dan!
Where did you get the marine intakes?
I've run with just the vents, just the vents and hoses, etc. and found no major difference in performance. For sure not running lean right now.
Haven't decided what I want to do with it all next--- just gonna ryde with it like this for awhile and see if anything else comes out in the way of intakes.
Then again there's always that Aerocharger that hopefully will really hit the market--- just wish it wasn't so dang expensive.
Very cool! Thanks for posting this (I have been out of town for a week)
I think I am going to try some silicone turbo hose fittings and PVC pipe (if I can find 2.5 inch PVC)
They are available on Ebay and is for intercooler piping and such Then I am going to install a UNI filter on the end of each and just eliminate the Evo filter but keep the Evo intake.
Interesting... please post pics of what you end up doing!
hehe. i have been pondering with same idea for over a year.
time and money is keeping me from doing it.
not only making scoops out of fiberglass hard work and expensive to paint and i will be making scoops and duct in the dark without any scientific test. if you don't have brp fogs, at least you can run the ducts to there.
also i will have to make a airbox on top of evo's intake so about same amount of air will go into each cylinder rather than one duct feeding one cylinder. i guess if i keep the duct the same length, may be that will do the trick without a airbox.
there are some polyurethane tubing that are rigid but somewhat flexible in all kinda sizes and elbows will be real good for ducting and cheaper than k&n universal duct but silicone ones will be about the same i guess.
6 states down 42 states to go
Do a quick ebay search for "intercooler pipe 2.5" and you will se what I intend to use. Looks like $100 will get you what you need (plus the uni filters for the ends of the pipes)
