Results 1 to 5 of 5
    Dec 2020
    Down South
    Default What do you prefer to use for lifting your Spyder/Ryker?
    Just wondering what method people prefer when jacking/lifting their Spyders/Rykers: Ramps, floor jacks, or the Spyder/ATV/Motorcycle lifts?
    Last edited by Peter Aawen; 05-06-2024 at 05:15 PM. Reason: \ = program command; / = fwd slash for grammar/punctuation. ;-)
    '20 RT Chalk Metallic
    Sep 2020
    Middletown, NJ
    Combo of ramps up front and jack at end of center rail for oil changes. If doing rear tire, just the jack in the back. If taking front wheel off, the jack moves to the wishbone.
    2020 RT base , Chalk White
    Mar 2015
    forrest above Reno, Nv
    Harbor Frieght lift, jack stands in front and a large cube of wood(with a handle) for the back.
    2014 RTS , Circuit Yellow
    Northern Kalifornia
    Depends on what I'm doing but mostly I raise my RT for an oil change. Car ramps for the front and a small conventional floor jack with a block of wood under the rear shock for the rear. If I'm working on the front for whatever reason, I use the HF motorcycle lift.
    Feb 2012
    Spring City,Utah
    I use jacks or ramps. I tried lifting it by hand once but it was just too heavy.
    I use a HF ATV lift left over from my Venture days and ramps for as jack stands. If I am doing tires I just use the HF jack
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
