Results 1 to 11 of 11
    Jun 2018
    Pa.
    Default Will car ramps be okay to work under a Spyder
    Hi All:
    I am thinking of adding underneath lighting, and what I see is I need to get under the bike to install the light strips. Would car ramps be safe and provide sufficient room to install underneath lighting?
    Thanks in advance,
    Jim
    2017 F3-Limited
    Quote Originally Posted by JimH View Post
    Hi All:
    Thanks in advance,
    Jim
    Yes .... I don't know of any after-market car ramps that can't hold the weight of any Spyder ...... To achieve more space to work, I'd turn the ramps backwards, and back onto them. ...... then use a floor jack, or scissor jack under the metal mounting TABS for the rear shock ..... In VERMONT, under vehicle lighting is illegal, but maybe your State allows it?? ..... Or you could put it on a switch, so you can shut it off easily .... Good luck ... Mike
    Sep 2016
    Chillicothe, Oh.
    I use car ramps anytime I need to be under there.
    2015 RT , Black
    Durham,Maine
    x3
    2012 RTL , Pearl
    Oct 2020
    Arizona
    Traction to back onto ramps might be an issue.
    Jan 2022
    North Dakota
    I backed onto mine with no problem. Mine are composite and have rubber tabs underneath. No problem at all.
    2021 RTL
    2021 RTL , Asphalt Gray
    Sebring, FL
    Sure nuff Jim, it works for me every time.
    Danbury Connecticut
    Yes
    IBA #47122
    2020 RT Limited Asphalt Grey
    Feb 2012
    Spring City,Utah
    I use my ATV/Motorcycle jack to lift it up, then put the ramps under it backwards so they don't interfere with me being underneath. For me, it is less hassle to jack it up & then place the ramps.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    Agree with Mike....just used car ramps (backing up onto them) to change my engine oil. I put chocks under the front wheels, and add a floor jack to level the trike.
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Jun 2018
    Pa.
    Thank you to everyone who responded with advice, I really appreciate everyone taking the effort to answer and provide input.
    Jim
    2017 F3-Limited
