Results 1 to 6 of 6
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    Default Anyone installed Pedal Box/Pedal Commander on 2024?
    Has anyone installed the pedal box or the pedal commander on a 2024 RT Limited?
    Last edited by Peter Aawen; 04-15-2024 at 04:27 PM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member Maplehawk's Avatar
    Dec 2023
    Saint Cloud, FL
    I inquired at Slingmods.com and their web site says that the 2023 Pedal Commander is not compatible with the 2024
    Login & Earn 300 Points when purchasing this item
    Part Name: canam-spyder-pedal-commander
    Part Number: SM-7386
    NOT COMPATIBLE WITH 2024+ MODELS
    They don't have anything listed for the 2024, I also went on the Manufacturers web site, and they also don't list one for the 2024 Model Year
    Last edited by Peter Aawen; 04-15-2024 at 04:29 PM. Reason: Many have difficulties with reading fine Red coloured fonts! :-/
    2024 RT Limited, Petrol Metalic Sold, replaced with Goldwing
    Baja Ron Sway Bar
    TricLED Front Fender Reflectors with Sequential LED Turn Signals & Running Lights
    Show Chrome LED Trunk Lights with Run, Brake & Sequential Turn Signals
    Mo-Door Garage Door Opener
    Fobo Electronic Tire Pressure Monitoring System
    Show Chrome Heavy-Duty Replacement Rear Trunk Lid Lift Support Strut / Shock
    Show Chrome Trunk Mounted Luggage Rack
    SpyderExtras Billet Aluminum Handlebar Riser Kit
    indpls in
    not sure if you need i feel much more response and power than my 21 with stage 2
    Active Member JB62's Avatar
    Feb 2024
    Dover Delaware
    I emailed Lamonsters and was told they don’t have one yet for the 2024 and something is different from 2023.
    Oct 2017
    Palm Coast, Fl
    I installed a Pedal Commander to my 2024 S2S and the Commander immediately failed. Lights started blinking and it got really hot. I'm sending the Commander back to the factory for diagnosis.
    It is not uncommon for manufacturer's to change something just to foil the installation of aftermarket components. BRP is particularly good at this.
