Results 1 to 10 of 10
    Mar 2018
    mississippi
    Default Running 16" PPA Rims, any suggestions on where to get tires to suit?
    I have a 2015 RTL. I need to replace the front tires. I currently have Federal Formoza AZ01 on the front. I am having a hard time finding the same tires online. Does anyone have a suggestion on where to find this tire or suggest a replacement tire for it?
    I forgot to mention that my RT has 16 inch PPA wheels. Makes it harder to find certain tire sizes.
    Last edited by Peter Aawen; 04-02-2024 at 05:08 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    2015 Can Am Spyder RT Limited
    Magic Mirrors
    Short Antenna
    LaMonster Dual Power Plate
    LED Headlights
    LED Fog lights
    Vibration Damper
    Spyclops
    Spyclops II
    Utopia Back Rest
    Oct 2022
    Jacksonville, IL
    I have a 2016 RTL and put Vredistein 175/55R15 on it. I updated the sway bar and it handles the curves seamlessly.
    2016 Spyder RTL SE6
    Mar 2021
    Maryland
    You can't go wrong with the Vredestein quatrac. Great grip in the corners and I have been out in heavy downpours and they stay planted on wet surfaces.
    2020 F3 SE6
    2020 F3 , Black
    165 or 175 Vredistein's are a great tire on the 2013-2019 Spyders. The 175 is a bit too tight on the 2020's and later.
    Mar 2015
    Indianapolis, IN
    Many in my "circle" have moved to the ContiProContacts due to not being able to find the Federals any longer.
    Similar to what BajaRon said above with a slight adjustment - I wouldn't use 175/55R15 ProContacts on the one piece fenders which started in 2019+. I'd use 165/60R15 instead. If you have a Pre-2019 with the 2 piece fenders (top middle is a separate piece not molded) then either would fit.
    Joshua
    2016 Spyder F3S
    2019 Spyder RT Limited
    2022 Ryker Rally
    2016 F3S , Triple Black
    Mar 2018
    mississippi
    Magic Mirrors
    Short Antenna
    LED Headlights
    LED Fog lights
    Vibration Damper
    Spyclops
    Spyclops II
    Utopia Back Rest
    Mar 2015
    Indianapolis, IN
    Quote Originally Posted by SOlsenPHS View Post
    That's an important piece of information considering it's not stock. Most suggestions you get won't help.
    Joshua
    2016 Spyder F3S
    2022 Ryker Rally
    Per the American Head Honcho at Federal Tires a several years ago, the Formoza AZ01 could no longer be imported. It was a tariff issue.
    Faribault, MN
    Have you checked with the folks at PPA wheels, I'd think they would have a list of tires that would fit.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Feb 2016
    Start here: https://www.tire-size-calculator.info/
    Use your current tire size, and place different new tire sizes in the proper cells. This will give you a graphical representation of the size differences. Since tire size numbers represent a ratio, the graphics help to visualize physical size differences. You can then look for a few different tires in different sizes that will work, and also be available in 16". For instance, 165/60-15 is VERY close to a 160/50-16. This would allow you to shop for tires sized 160/50-16.
    2020 RT Limited , Marsala Red
