Results 1 to 25 of 25
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    Default Anyone Guess what this hole is for? 2021 RT...
    Last edited by Peter Aawen; 03-30-2024 at 08:15 PM. Reason: Added text to the post so viewers/readers have SOME context... ;-/
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    FOBO 2, Trunk rack, Afterburnerz taillights
    Drinks2go cup holder, replaced the seat strut
    Garmin Drive Smart 71 GPS, Large brake pedal
    White pulley, Pedal Commander, Trunk Strut
    Laminar Lip wind deflector, side windshield wind deflectors
    Home made belt guard, Shorty antenna
    Show chrome wide windshield, Belt dampener
    Top cuffs and Mirrors
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    Florida Swamp
    Maybe to let the dirt-dobbers in so they can build nests on everything?
    2019 F3-S , Black & Silver
    Show us a picture from farther back so we can see where on the bike this is.
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by SkipH View Post
    Maybe for aftermarket lighting on passenger foot pegs
    10W40 Amsoil Synthetic Motorcycle oil
    If in Doubt, Don't Do It!
    I'm sorry, but given that we have absofreakinlutely NO idea of where it might be.... without any other info &/or further context, it could be that it's a drain in one of the splash trays underneath the bike, only the rubber insert bit has come out??
    We need more context - where on the Spyder is it?? Is it even on a Spyder, or maybe it's on/in another bike?? Is it in an upper panel or a side panel?? Inside the frunk maybe?? Up near the Handlebars or down the back near the license plate??
    Nov 2021
    Nevada
    First Clue: Turn the picture right 90 degrees.
    Not my fault the picture was turned......
    Skip H.
    I still can't tell where it's located, but I can tell you it's not a factory hole. See the burrs around the perimeter. It was drilled, not formed when the panel was made.
    Oct 2020
    Arizona
    Port to let the red dust/rust out from the drive sprocket.
    Sorry Skip, if you can't help us by taking a step back and taking another picture to post up here, I doubt we'll really be able to be of much help!! You need to help us a bit so that we can help you!!
    As for your pic turning sideways, that's most likely because you took it in Portrait Mode on your phone or camera - the Forum software doesn't like that and won't handle them well at all - you need to take any pic intended for the Forum in Landscape Mode, and you need to get into Landscape Mode by dropping the Top of the Phone/camera to the Left, turning the Phone/camera 90° anti-clockwise! Do that, then when uploaded here it should post in the correct orientation!
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    I have the exact same year and model as you. As someone else stated. That hole is not factory drilled. The area under the passenger footrests has no pre-drilled holes in it. Whoever owned that Spyder prior to you drilled that. IMHO, quite unnecessary I'd say.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Florida Swamp
    I don't know what it is and neither does Google. Just did a Google image search and nothing that looks anything like it came up.
    Dec 2020
    Hartwell, Ga
    I have to agree with Valkrocket, not an OEM hole! Ask the person who you purchased it from.
    My guess would be the previous owner was planning to install a light and needed a hole to run the wire through.
    Feb 2020
    Minnesota,USA
    What I said in post #4.
    Apr 2012
    Florida
    That's where the optional "Flux Capacitor" mounts to the bike. Tom
    2020 Petrol Blue Metallic RTL
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Tango View Post
    OK! So enlighten me, never to old to learn! "What the is a Flux Capacitor?" Bill
    OOOPS, found it! at the parts store next to the blinker fluid and above the muffler belt.
    indpls in
    well im gonna say u bought that used 1st owner had can am floor board lights and took them off i just put that same hole on one that im working on last night
    Active Member PaSpyderRyder's Avatar
    Jun 2013
    Carlisle, PA
    It is most definitely a hole that was drilled for lights on the passenger floorboard.
    Durham,Maine
    2012 RTL , Pearl
    Nov 2021
    Nevada
    Ah Guys, Not a real mechanic in the replies.
    Has anyone removed that pod plastic on the left side of the rear wheel?
    You know, the 3 screws that holds them on, especially the front screw?
    Well, that screw is a bastard to reach and remove AND replace. I changed the front one over to 10 mm bolt
    which it made it somewhat easier to get out, but I still had to stand on my head to get it out while working on the floor.
    This 80 year old mind finally turned on the light bulb and sez "if you drill a hole right here, you can reach that bolt easily".
    So I did and that's the end of that problem.
    Skip H.
    And here I was thinking it was to let the sunshine in!
    Sounds like it was more along the lines of 'letting the frustrations OUT!'
    Mind you, as any good home spannerspinner learns very quickly; it's NEVER a good idea to have a hole-saw or sawz-all or anything similar within easy reach whenever you're working on anything mechanical or electrical!!
    Florida Swamp
    Sounds like a good idea. I think I saw a box of various sized holes for plastic on the web while I was looking for parts. I might order it. It would be handy to have a few different sized holes on the shelf you could just drop in where you needed them.
    Durham,Maine
    Quote Originally Posted by Gwolf View Post
    Make sure you have the right size drill bit in before you make your sieve!
    2012 RTL , Pearl
    Apr 2012
    Florida
    Quote Originally Posted by Knizar View Post
    Did you get the full synthetic blinker fluid? It's supposed to be good for a year. Tom
    Florida Swamp
    Not a problem, got several hole re-sizers in my tool box.
