Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Quote Originally Posted by WRCLVR View Post
    Ah... thank you very much for the quick primer. That is different.... lol. I'm gonna make the dealer pair the Samsung to the bike. After watching that, I will pair up my Sena 50S comms. Don't have Apples so lack of Carplay is not an issue.
    Does Google Maps work well with the new 2024's?
    Well as promised but only one teaser pic...
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
  2. #27
    Apr 2012
    Greenville, SC
    It should work fine when CarPlay is finally enabled. Won’t know for sure though until they enable CarPlay support.
  3. #28
    Nov 2022
    Georgia USA
    Thanks! Another question... is there an adjustment for the back rest? This is on my new 2024 Sea to Sky with the matching S2S back rest. IIRC, the older BRP back rests, like the one I put on my 2023 Sea to Sky, had a screw to adjust the rake of the back rest, so that it could lay flat against your back, and not dig in under your shoulder blades...
    LMK please?!
  4. #29
    Member Spyderjim2016's Avatar
    Dec 2017
    Delancey, NY
    Just saw the 2024 S to S yesterday at the dealer. Thoughts on what your impressions are would be appreciated!
    Sorry for the bad post before, what’s your impression of the 2024 S2S so far? Saw one yesterday at the dealer and thinking of upgrading. Any special $ discount?
  5. #30
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    Thanks ! Another question ...is there an adjustment for the back rest? This is on my new 2024 Sea to Sky with the matching S2S back rest. IIRC the older BRP back rests like I put on my 2023 Sea to Sky had a screw to adjust the rake of the back rest, so that could lay flat against your back and not dig in under the shoulder blades
    LMK please !!
    Not sure about the s to s but my 2024 RTL has an adjustment screw. You have to pull the upholstery up in order to see it.
  6. #31
    Active Member Johndeeredoo's Avatar
    Aug 2018
    South haven michigan
    I miss the "glove box" between the handle bars on my RT.
    I still don't know about the "vent" hole in the front of the RT, you can look through them and see wires. I hope there water proof in some way.
    I miss the one lock system om my RT, I have to lock the trunks independently.
    You can't prelock the trunk.
  7. #32
    Mar 2022
    NH
    So I'm also thinking of pulling the trigger on a 2024 - have a 2015 RTL w/65K miles -- runs well, but like the look of the new leg room on these newer versions. Pretty sure the dealer will low-ball a trade...
    Assume there is no discounting - we're all paying list?
  8. #33
    Aug 2018
    Quote Originally Posted by KW1M View Post
    My dealer knocked off about 2K off list.
