Any Suggestions on where to place a Spyder emblem?
I have two shiny silver Spyder emblems. I'm debating on where to stick these? Does anyone have any pictures of these attached to an F3L ?
_________________________________
GR Horst - Reading, Pennsylvania, U.S.A.
Looks like metal.
You don't have much choice, if they are metal, they will have to go on a flat, smooth area. Not many flat smooth areas on a Spyder.
These are plastic. But your point is valid regardless. There are several areas that are flat, but only a few.
HI GRHorst,
How about on the frunk, or on the saddlebags, or on the trunk( if your spyder has one).
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Well you have two so balance it out one on both sides Saddle bags maybe helps keep symmetry for pics & if is using sticky back foam tape like 3m, suggest prep cleaning bag surface with rubbing alcohol, let air dry then apply.
I've seen them placed on the speaker grills, doesn't affect the music that I know of.
If in Doubt, Don't Do It!
Wherever the most bugs end up or somewhere dark maybe.
Yes they came with the 3M 2-sided stickies. In holding them up to the bike, the iceberg blue doesn't show them very well. But next to the black on the trunk or the black around the headlights/fog-lights, they show up much better. I never would have thought of putting on the speaker grills. As far as collecting bugs ... well ... hmmm ... cleaning bugs out of these emblems doesn't sound like an enticing task.
I'll post pictures eventually.
Spyder Emblem Added
I ended up putting them on the back where they are easier to see and may pick up some headlight glow.
Reason: better pic
GRHorst,
On my previous Spyder (a 2014 RTS-SE6) I had one, and I placed it on the nose of the windshield, between the 2 headlights where it did not block anything.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Originally Posted by Deanna777
GRHorst,
Deanna
That was a place I considered. I wondered whether it would stay on if mounted up where it picks up more wind. Apparently it stayed on for you.
