Results 1 to 9 of 9
    Feb 2024
    Missouri
    Default Does my new Spyder need a Break in period or service? First service?
    I upgraded from a used 2021 F3 base to a brand new 2023 F3 Limited. I have owned new motorcycles and vehicles in the past, all had some "break in" period and required service after X number of miles.
    Can the same be said for a new Spyder? Do I need to keep it under a certain MPH for X number of miles? When should I have the first service done?
    Appreciate any guidance.
    Last edited by Peter Aawen; 02-07-2024 at 01:15 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Quote Originally Posted by GrizzlyRyno View Post
    ..... your owners manual has guidelines as to initial operation ..... I have only brought my Spyder in for service to have Waranty issues done .... I have done all the maintenance work my self ... good luck ....Mike
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Any "break-in" will be specified in the Manual.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Feb 2022
    New Zealand
    Gidday and welcome.
    Running in, just the usual I guess, like dont lug it at low revs and dont wring its neck. Easy on the throttle and let it run.
    I know the BRP manual is something else but its worth reading it.
    2017 F3 Ltd
    Feb 2024
    Missouri
    Dont have the manual in hand yet, I will review once I pick up the bike.
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    You can download the manual from the BRP website
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
    Feb 2022
    New Zealand
    Bit of light reading if you want a preview.
    Its a PDF file.
    https://www.operatorsguides.brp.com/...p?modelId=2082
    2017 F3 Ltd
    Jun 2021
    It makes sense to read the manual even before you get it. Sometimes it takes reading something several times before it sinks in. Even the starting of a Spyder can be daunting if you’ve never done it. When I picked my first one up I went for some lunch after the purchase and upon trying to start it , I had already forgotten the procedure and had to call the dealer for instructions.
    2023 RT Limited , Red/ black
    Durham,Maine
    I nosed mine into a parking spot and forgot how to get it in reverse!! It took a few minutes to remember what the magic trick was!
    2012 RTL , Pearl
