Results 1 to 10 of 10
    Jan 2024
    Texas
    Question 2019 RT Handlebar grips getting too hot, is this normal?
    I love the heated handlebar grips in my new (to me) 2019 RT LTD. But even on low, they get too hot, even through my gloves. I find myself turning them off until my hands get cold, then turning them back on again, rinse and repeat. Granted it's in the 40's and 50's, so not freezing, but is this normal?
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system
    Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock
    Dec 2020
    Hartwell, Ga
    I turn mine to low on my 2020 RT and find it to be perfect for me.
    Can you tell if there is a difference in the heat between the high and low settings?
    Nov 2018
    Waynesboro, PA
    Quote Originally Posted by Allen42 View Post
    Hello Allen42, welcome to the forum. you might want to try this https://www.lamonstergarage.com/lamo...er-like-grips/ . They made my grips more comfortable, and you will get just a little less heat.
    My Spyder
    2012 RTL , Brown
    No ..... most complaints about the heated grips are they don't get hot enough .... Get a pair of "grip puppies" or something similar .... Mike
    Jan 2024
    Texas
    I haven't even tried high yet.. will do.
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    Sep 2016
    Chillicothe, Oh.
    Low setting on my 15 RT is just about right with gloves on. High gets too warm unless I have heavy gloves. The grips on my Suzuki get very warm on low and I switch them off intermittently. The factory grips on my Triumph are very adjustable and easy to get just right. I guess it depends on the machine and whatever company they outsource the grips from.
    2015 RT , Black
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Same with the grips on our 2014 RTL. I have to turn them off of the Low setting after 10 to 15 minutes. Very Hot!
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Feb 2020
    East coast
    I have foam grip covers on my RTL, and I find the low setting too warm unless I have heavy gloves on.
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Cosmo View Post
    Mine too.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    When it's so cold I'm turning on the grips, I will be wearing a deer skin gauntlet with Thinsulate. Low is just fine for me. So are the complaints with riders wearing a thin glove?
    2021 RT LT
