Not the first time you've asked that Deanna, altho maybe the earlier 'asks' were not specifically for just the Ltd's; but a few F3 owners have answered in the affirmative.
There's a post about an F3-T with this issue back around post #167....
Then there's Mike Ard at post #289 wondering if, given the difference between the RT display and the F3 display, his F3's 'Bad Key' error isn't the same problem as the DESS error? BRP initially replaced his DESS Antenna, then when the problem continued, replaced the entire DESS Module - which, BTW, is apparently exactly the same part# as those in the RT's.
Another F3S with a Bad Key at posts #487 & #490 from SpyDerSts...
Then wengerda, with a 2016 F3L at posts #572-#574
And that's only searching up to page #24....
