Results 1 to 7 of 7
    Member Chahn's Avatar
    Jan 2024
    Arizona
    Default Thinking about buying a 2013 ST Ltd or 2016 F3-T- anything bad about them?
    I'm thinking about buying a 2013 Can Am Spyder ST Limited with 13,000 miles on it. I'm new to the Spyder so is there anything bad about the 13?
    I've read about the heat issue.
    I'm also looking at a 2016 Spyder F3T...
    Thanks for any help!
    Last edited by Peter Aawen; 01-14-2024 at 01:30 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    2014 ST LIMITED , 11 Silver
    Mar 2013
    Marion, Arkansas
    If I was you I'd be looking seriously at the 2016 F3T. The 2013 has the 998 engine plus its only 5 speed. Parts are getting harder & harder to find on these old Spyders. Less maintenance cost on the 1330 engine, plus you don't have the heat issue with the F3T. Just my 2 cents.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Quote Originally Posted by Chahn View Post
    I'm thinking about buying a 2013 can-amŪ spyderŪ st limited with 13,000 miles on it. I'm new to the Spyder so is there anything bad about the 13.
    I'm also looking at a 2016 spyder F3T
    Thanks for the help!
    Please add an "asking price" if possible. The 2016 F3T may be a better option. The heat issues were solved, the 2016 has the three cylinder engine, which many prefer over the 998 twins. I have had three 1330 engine equipped Spyders out of the seven owned. Two of them were F3 limiteds. Those were MY favorite Spyders.
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    I would get the F3-T It has the 1330 motor
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    May 2013
    Apex, N.C.
    I must agree with the above comments. I would also go with the F3T. Later model and easier on maintenance. Good luck shopping.
    Dec 2012
    Murphy, NC
    I also agree on the F3T. My first Spyder was a ‘13 STS. Great Spyder but two years later I traded it for a ‘15 F3S. I like the F3 much better.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Durham,Maine
    I would get the newest model my pocketbook could find!
    2012 RTL , Pearl
