Page 34 of 52 FirstFirst ... 2430313233343536373844 ... LastLast
Results 826 to 850 of 1283
  1. #826
    Nov 2018
    Waynesboro, PA
    My Spyder
    2012 RTL , Brown
  2. #827
    Active Member Gldwnger's Avatar
    Apr 2015
    Kitts Hill, Ohio
    Speaking of Christmas parties, Do you know what they call someone who doesn't believe in Christmas parties?
    An "EGGNOG STIC"
  3. #828
    Jun 2017
    Rapid City, SD
    Merry Christmas everyone!
    HE>I
    2017 RT , Asphalt Grey
  4. #829
    Florida Swamp
    Christmas Spinner for today............
    2019 F3-S , Black & Silver
  5. #830
    Apr 2015
    Kitts Hill, Ohio
    Quote Originally Posted by Gwolf View Post
    Geez!! You might hafta start putting up a
    'WARNING: Flashing or strobe effect in this image may potentially trigger adverse reactions in photosensitive people. Viewer discretion is advised.'
    post before each of these GIF's! That one's a real hum-dinger!!
    How many actual images are there that make it up; what's the refresh rate; and how do you get it so fast?? My aging tablet seems to run it for a bit, then sorta stutters for maybe a second or part there-off before trying to catch up... I haven't looked to see if the 'phone does the same thing, but it is a fair bit newer, so maybe not - or maybe it's just my aging eyes not managing to keep up?!
  7. #832
    Florida Swamp
    It is only 4 frames. I ran the speed higher by dropping the lag time between frames down lower. It is actually a fractal image that I created with a different image program. I removed parts of it one color at a time, until the total image size dropped below 100 KB. The end image is only a partial fractal now. What is left is just the skeleton of the fractal image it started out as. Colors were removed because the number of colors involved in an image increases the image size. It is not really spinning, it just has 4 different positions in the 360 degree circle and moves fast enough to fool the human eye into thinking it is spinnng around.
    Most everything you see that appears to be moving is not. The television, movies, videos, and other things which appear to be in motion are just flashes of pictures in slightly different positions changing faster than the human eye can follow, so they appear to be moving.
    Using the same method from a different perspective, it is possible to have a rapidly spinning object, which appears to be staionary to the human eye. The way to get this is by having the spinning points at exactly fractional angles of 360 degrees. It has to divide in even numbers. At the flash of each frame, the points will always be stopped at the same place. They may appear to be different colors, but the object will not appear to spin. It is all done with math and speed adjustments. The object is spinning around, but appears to be stationary with just colors changing on the points.
  8. #833
    Jun 2017
    Rapid City, SD
    HE>I
  9. #834
    Florida Swamp
    Load of ???????????? Limerock, gravel, Gypsum, corn, whatever............
  10. #835
    Jun 2017
    Rapid City, SD
    HE>I
  11. #836
    Potatoes, beets, or onions! At least here in Idaho!
  12. #837
    Jun 2017
    Rapid City, SD
    HE>I
  13. #838
    Florida Swamp
    Not that many old doctors around either. If they have the secret to long life, they must not be using it.
  14. #839
    Florida Swamp
    Happy New Year .............
  15. #840
    Florida Swamp
    Looks better with a dark background.
  16. #841
    Jun 2017
    Rapid City, SD
    HE>I
  17. #842
    Apr 2015
    Kitts Hill, Ohio
    Jun 2017
    Rapid City, SD
    Yeah, I’ve received a few of those.
    HE>I
  19. #844
    Feb 2012
    Spring City,Utah
    Yeah. Me to, but back in the 50's
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  20. #845
    Florida Swamp
    Four alarm on Main and Walker......
  21. #846
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    Owning a motorcycle is like peeing yourself ! Everyone sees it, but only you can enjoy the warm feeling it gives you !
    Brgds Martin
  22. #847
    Jun 2017
    Rapid City, SD
    HE>I
  23. #848
    Nov 2018
    Waynesboro, PA
    My Spyder
    2012 RTL , Brown
  24. #849
    Jun 2017
    Rapid City, SD
    Happy New Year everyone!
    HE>I
  25. #850
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    RapidSpyder, I don’t know where you come up with a these, but keep them coming. I have really enjoyed reading the posts.
    Thanks buddy
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
