Results 1 to 4 of 4
    Oct 2023
    Missouri
    Default Any FAQ or threads detailing F3S seat Removal? Advice?
    Can someone guide me to an FAQ thread or any threads detailing how to remove the seats on a 2016 F3S?
    Last edited by Peter Aawen; 11-14-2023 at 05:27 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Dec 2012
    Murphy, NC
    Remove the passenger seat first. Then you will see two torx bolts or hex bolts on the bottom rear of the rider seat. Remove those and then you can slide the seat back and off.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Oct 2023
    Missouri
    How is the passenger seat removed?
    Feb 2022
    very southern tip of Texas
    Push ignition key down, then turn clockwise, then lift off passenger seat. Same thing as for frunk , except turning key ccw.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
