Results 1 to 14 of 14
    Active Member randyandsandy74's Avatar
    May 2014
    Default 2012 RT with check engine but no codes, any ideas?
    I have a 2012 RTL and I'm getting a check engine light. When I check for codes, I get a clear screen. Any Ideas out there?
    Last edited by Peter Aawen; 09-28-2023 at 05:42 PM. Reason: Expanded title to briefly ask the question... ;-)
    Quote Originally Posted by randyandsandy74 View Post
    If it's an active code ( the icon is blinking ) you should get the code number...... for the past 5 mos. mine has been blinking almost every time I ride. Plus I get the " Limp Home " message .... but the Spyder runs great ( I'm actually getting 2 MPG better since this started ..... Mike
    Bossier LoUiSiAna
    Unfortunately & on going https://www.spyderlovers.com/forums/...k-engine-light. Mean lil gremlin whatever it is.
    May 2014
    thanks Mike , do you know of any way to cancell the check engine light?
    If it's an active code, it's likely to re-appear ( because there is an issue ) .... sometimes " gremlin codes " can be removed by disconnecting the Battery terminals and touching them together.... then re-attach ( adding Star washers ) ..... can't hurt to try it .... Mike
    Feb 2012
    Spring City,Utah
    Mike since it doesn't seem to be bothering how the Spyder runs, have you looked into what may be causing that light?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2014
    I'm now getting a PO174 code. Does anyone know what that code is?
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    According to the codelist I have, Code P0174 = ECM System too lean Bank 2
    Brgds Martin
    Dec 2012
    Murphy, NC
    It is possible that the rubber hoses on the left side of your engine might have cracks in them. Many riders switch to silicone hoses which can be bought at NAPA.
    2020 F3 Ltd
    Spyderpops Bumpskid
    May 2014
    Thank you everyone for all the help and suggestions
    Jan 2023
    Clifton TN
    I'm having the same problem with my 2022 RT Limited with 2000 miles. Check engine light on but no codes displayed...
    Last edited by Peter Aawen; 11-02-2023 at 06:00 PM. Reason: Fixed attach display ;-)
    Quote Originally Posted by DesertLawman View Post
    Sorry Desert, but I'd guess that your 2022's issue is probably not going to be the same as that which caused this on the OP's 2012 RT; but then again, that Check Engine Light does tend to be a bit of a 'Catch All indicator' for a whole range of issues - some of concern, many not...
    Is there anything else you can tell us?? Any momentary flashes of other lights maybe? Engine surging issues?? Anything??
    Durham,Maine
    Are you the only owner of this bike? Have you done any upgrades like the vac lines on the map sensor, plug wires and plugs?
    2012 RTL , Pearl
    Sep 2012
    Stetson, Maine
    A bad purge valve can cause this issue also. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
