Results 1 to 8 of 8
    Sep 2023
    Harford county Maryland
    Default Anyone installed a Sirius XM radio receiver on their RT? Any hints?
    Has anyone installed a Sirius XM receiver/player on their Spyder RT? I would like to install one on my S2S.
    Last edited by Peter Aawen; 10-09-2023 at 12:03 AM. Reason: Expanded title to briefly ask the question/s... & removed ' 's before punctuation. ; -)
    Mar 2017
    Salisbury,NC
    Why don't you just add your smartphone to the Sirius plan and Bluetooth to helmet speakers? Might be able to put phone in storage and use data cables to spyder speakers
    Aug 2019
    Stoughton, WI
    I have IHeart and SiriusXM apps on my Iphone. They blue tooth nicely to my 2022 S2S, with clear audio. When/where service is spotty, I have a trusty IPod in reserve
    2022 RT Sea To Sky
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    I also use the XM app on my phone along with Pandora and MP3 files. Bluetooth works great and was easy to set up! One account works everywhere I want it
    2021 RT LT
    Jun 2021
    Bossier City, LA
    As others have said, the app should work in most instances.
    If you're wanting to use something that doesn't involve the phone, then something like the kit I have linked below should do the trick.
    I have used a "portable" kit for years (10+) in various vehicles (currently in my '99 full-sized van), and it's always worked great.
    https://www.amazon.com/Satellite-Motorcycle-Installation-Commander-Adjustable/dp/B09JL8WSRT/ref=sr_1_8?crid=X003JQFEPQNI&keywords=siriusxm+mot orcycle&qid=1696852916&sprefix=siriusxm+for+moto%2 Caps%2C1100&sr=8-8&ufe=app_do%3Aamzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
    --Exco
    2021 RT-L only has a few cosmetic mods
    Sep 2020
    Middletown, NJ
    I installed an XM receiver on my '20 RT. I connected the XM's audio out to the AUX IN plug and used the 5v power from the USB plug. I ran the antenna under the tupperware to the back and glued it to the right top (opposite the RT antenna). If it rains, I cover it with a ziplock baggy.
    2020 RT base , Chalk White
    Nov 2016
    Upstate NY
    I use a Siriusxm stratus7 on my S2S. Mounted it on top of the glove box door and plugged it in in the glove box. Mounted the antenna on the dash under the windshield. Had to buy a USB cord to power it. They make one specially for xm receivers.
    Quote Originally Posted by MCole View Post
    I put an Onyx EZ into the glove box of my `14 RT ..... removed the OEM plug from the rear trunk and stripped it from the harness .... I then ran the cable up the right side ( under tupperware ) and drilled a hole in the right side of glovebox ... mounted ithe plug and made a sheet metal holder for the Onyx..... I have pics of it in an Album .... I don't know how much room you have in your glovebox , so it may or may not fit ..... I can change stations on the fly if I have to ....good luck ...Mike
