So the dealership I've been using for warranty work and most recently a new rear tire, is having a tough time aligning the drive belt. Seems to me they want to rush it through and get to the paying jobs. (can't blame them I guess) Anyway... I have been doing some research and am going to adjust it myself. What has/is anyone using for a wrench on the axle nut? I have been to all the usual suspects, and no one has a 36mm wrench that "I liked the look of".
2018 F3 Limited
Reason: Expanded title to briefly ask the question... ;-)
Shallow socket off Amazon and just a cheap import wrench from Northern Tool. Don't overthink it - you'll only use it a few times and it's plenty strong enough even if it looks like crap.
Lamonster Garage sells the 36mm socket used for the oil filter and rear axle nut along with the hex and Allen sockets used on the oil plugs. I believe they are $37 sold together. You should be able to get a 36mm wrench at Harbor freight.
I bought a socket and wrench from Amazon. Socket & Combination (open end and box end wrench) which I cut in half and make two wrenches.
Also use my 1/2" drive torque wrench to finish the job.
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
HeliBars Handlebars
Kenda Kanine rear.
We bought a socket and wrench from Amazon (socket) and Northern Tool (wrench open end and box end) which could be cut in half and make two wrenches.
You must be a strong bugger, MS JETSON. I needed a 2’ breaker bar to release the 150lbs torqued nut……and I’m not a lightweight. I assume you use a bar of some kind on the end of the half wrench?
HeliBars Handlebars
Kenda Kanine rear.
Using a 1/2" 150 or 120 lb-ft torque wrench you can easily reach the required torque of 166 lb-ft on the axle nut. Here's how to calculate the torque wrench reading needed. https://www.norbarusa.com/Support/Ca...ension-Formula
I browse lawn sales and flea markets, and have bought some very old tools like adjustable wrenches ( for little money ) some of which are of the " Stillson " variety .... they are like pipe wrenches without the teeth .... some are also quite thin, like open-end wrench. ... they work great on the disk side nut .... Mike
What's not to like about the looks of a wrench? And we're talking about a $25/$30k machine here and we can't afford a wrench? Check out your local pawn shop.
They are not flea market finds, they are my family heirlooms.
If you can't find the 36 mm tools, then a 1 7/16 SAE is about 1/2 mm larger. On a nut that large the 1/2 mm would make very little difference. It sure would not slip or round the corners. So little difference in 36 and a 36.5 you would be OK with that on the very large nuts.
Speaking of Napa and Advanced, depending on the store and if you have an account with them, sometimes if you are only going to use the tool one time you can rent/ borrow the tool needed. It costs like $1.50 total. You put the tool value deposit down and receive it back once it’s returned. I’m guessing a 36mm socket would be on their list. I know the huge wrenches are on the list for rent. I’ve needed to adjust and remove that axle nut 3 times since 2017. I bought an extra long wrench off amazon for $30 as recommended above and cut it in half. I also bought a filter socket from HF. I am a tool lover. I have easy $35K easily if not more in snapon and Mac tools but some things are just dumb to have high quality when it is only used once or twice. If it was every year for maintenance then I’d think different and look for the high quality stuff but for removing the axle nut the amazon and Harbor Freight are just fine.
I can do 2 ways, axle wrench to get loose and oil filter socket with rachet to speed up, or can use the socket to get loose or torque but is 3/8 so need a an adapter for torque wrench and will be to close at muffler need to pull to side on some bikes.PXL_20231005_131349380.jpgfPXL_20231005_131443745.jpg
2018 F3 Limited
Read this thread to see the problem I have had in getting the alignment just right. https://www.spyderlovers.com/forums/...belt+alignment. Maybe your dealer was dealing with the same issue, i.e., the axle moving while torquing the nut.
I found that my axel also moved when trying to tighten down the axel nut. I solved the problem by running a ratcheting tiedown strap from the right front floorboard around the back tire and making it as tight as possible. This has kept my wheel from walking while tightening the axel nut.
I got my 36mm socket years ago from MAC, but back in those days I was making my living with the tools. I would not spend that kind of money today. NAPA, Advance, the internet, Harbor Freight are all good enough for as often as most of us will be using them. I think my combination wrench came from Walmart trailer hitch aisle and was for sure made in China and cheap, but it works.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
You have to torque each side toward the adjusters or that will happen.
Just exactly what do you mean? Since the nut has to turn clockwise to tighten, if the bottom section of it has more friction against the swing arm than does the top section that friction will tend to make the nut and axle move forward. There really isn't enough room to point the wrench any way but toward the back. And since torquing is rotational I don't see how you can make it directional.
