Results 1 to 25 of 33
    Nov 2022
    North Carolina
    Default What Rear Axle Nut Wrench are you using?
    So the dealership I've been using for warranty work and most recently a new rear tire, is having a tough time aligning the drive belt. Seems to me they want to rush it through and get to the paying jobs. (can't blame them I guess) Anyway... I have been doing some research and am going to adjust it myself. What has/is anyone using for a wrench on the axle nut? I have been to all the usual suspects, and no one has a 36mm wrench that "I liked the look of".
    2018 F3 Limited
    Last edited by Peter Aawen; 10-03-2023 at 05:38 PM. Reason: Expanded title to briefly ask the question... ;-)
    2018 F3 Limited
    Member MS JETSON's Avatar
    Jun 2014
    LENNOX, SD
    We bought a socket and wrench from Amazon (socket) and Northern Tool (wrench open end and box end) which could be cut in half and make two wrenches.
    Ms Jetson
    2021 Spyder RT Limited Chaulk/Dark
    Farkles:
    Drivers Backrest, K.O.T.T. Grills, Lamonster Handlebar riser
    Past rides; 2007 Lehman Jackal, 2014 Spyder RTS
    Flatlands of South Dakota
    Lennox,SD
    2014 RT , Congac
    Apr 2023
    TX
    Shallow socket off Amazon and just a cheap import wrench from Northern Tool. Don't overthink it - you'll only use it a few times and it's plenty strong enough even if it looks like crap.
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Lamonster Garage sells the 36mm socket used for the oil filter and rear axle nut along with the hex and Allen sockets used on the oil plugs. I believe they are $37 sold together. You should be able to get a 36mm wrench at Harbor freight.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Oct 2015
    Lynden, WA
    Default Belt Alignment
    I bought a socket and wrench from Amazon. Socket & Combination (open end and box end wrench) which I cut in half and make two wrenches.
    Also use my 1/2" drive torque wrench to finish the job.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Northern Kalifornia
    You don't have to torque back on at 300lbs. 100+ is plenty.
    Mar 2008
    Hesston, PA
    I use a 1 7/16" american size socket & wrench...larryd
    Harrington, Australia
    So if 100 is OK, why does the workshop manual say 150 +/- 10 for the 2013+ models, 2 dogs?
    HeliBars Handlebars
    Kenda Kanine rear.
    Quote Originally Posted by MS JETSON View Post
    You must be a strong bugger, MS JETSON. I needed a 2’ breaker bar to release the 150lbs torqued nut……and I’m not a lightweight. I assume you use a bar of some kind on the end of the half wrench?
    HeliBars Handlebars
    Kenda Kanine rear.
    Florida Swamp
    You can get a 36 mm wrench most any place that sells tools. They kind of big if you looking for one to carry around in the tool pouch.
    You can also get 36 mm sockets to fit 3/4 inch torque wrench and/or crowfoot wrench for the tool pouch. To carry in the tool pouch,
    get the socket and crowfoot wrench. Carry a sawed off breaker bar and couple of pieces of pipe for cheater bars.
    You could just cut the combination wrench in half and make cheater bars for it on the road.
    You still need the socket for the torque wrench, at least in your shop.
    2019 F3-S , Black & Silver
    This works great!
    https://www.amazon.com/Wheel-Torque-...s%2C271&sr=8-2
    Using a 1/2" 150 or 120 lb-ft torque wrench you can easily reach the required torque of 166 lb-ft on the axle nut. Here's how to calculate the torque wrench reading needed. https://www.norbarusa.com/Support/Ca...ension-Formula
    I browse lawn sales and flea markets, and have bought some very old tools like adjustable wrenches ( for little money ) some of which are of the " Stillson " variety .... they are like pipe wrenches without the teeth .... some are also quite thin, like open-end wrench. ... they work great on the disk side nut .... Mike
    Northern Kalifornia
    What's not to like about the looks of a wrench? And we're talking about a $25/$30k machine here and we can't afford a wrench? Check out your local pawn shop.
    Nov 2022
    North Carolina
    Found what I was looking for at Northern Tool. I may have grunted like "Tim The Toolman Taylor" while I was browsing...
    2018 F3 Limited
    Florida Swamp
    They are not flea market finds, they are my family heirlooms.
    If you can't find the 36 mm tools, then a 1 7/16 SAE is about 1/2 mm larger. On a nut that large the 1/2 mm would make very little difference. It sure would not slip or round the corners. So little difference in 36 and a 36.5 you would be OK with that on the very large nuts.
    Durham,Maine
    Harbor Freight!
    2012 RTL , Pearl
    Dec 2021
    Uniontown, PA
    NAPA , no problem getting it in stock or overnight to the store
    PA
    Speaking of Napa and Advanced, depending on the store and if you have an account with them, sometimes if you are only going to use the tool one time you can rent/ borrow the tool needed. It costs like $1.50 total. You put the tool value deposit down and receive it back once it’s returned. I’m guessing a 36mm socket would be on their list. I know the huge wrenches are on the list for rent. I’ve needed to adjust and remove that axle nut 3 times since 2017. I bought an extra long wrench off amazon for $30 as recommended above and cut it in half. I also bought a filter socket from HF. I am a tool lover. I have easy $35K easily if not more in snapon and Mac tools but some things are just dumb to have high quality when it is only used once or twice. If it was every year for maintenance then I’d think different and look for the high quality stuff but for removing the axle nut the amazon and Harbor Freight are just fine.
    Dec 2022
    Florida
    I can do 2 ways, axle wrench to get loose and oil filter socket with rachet to speed up, or can use the socket to get loose or torque but is 3/8 so need a an adapter for torque wrench and will be to close at muffler need to pull to side on some bikes.PXL_20231005_131349380.jpgfPXL_20231005_131443745.jpg
    Dec 2022
    Florida
    Quote Originally Posted by cjr00 View Post
    2018 F3 Limited
    Read this thread to see the problem I have had in getting the alignment just right. https://www.spyderlovers.com/forums/...belt+alignment. Maybe your dealer was dealing with the same issue, i.e., the axle moving while torquing the nut.
    Feb 2012
    Spring City,Utah
    Smile
    I found that my axel also moved when trying to tighten down the axel nut. I solved the problem by running a ratcheting tiedown strap from the right front floorboard around the back tire and making it as tight as possible. This has kept my wheel from walking while tightening the axel nut.
    I got my 36mm socket years ago from MAC, but back in those days I was making my living with the tools. I would not spend that kind of money today. NAPA, Advance, the internet, Harbor Freight are all good enough for as often as most of us will be using them. I think my combination wrench came from Walmart trailer hitch aisle and was for sure made in China and cheap, but it works.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Linden, CA
    Snapon
    Northern Kalifornia
    You have to torque each side toward the adjusters or that will happen.
    Just exactly what do you mean? Since the nut has to turn clockwise to tighten, if the bottom section of it has more friction against the swing arm than does the top section that friction will tend to make the nut and axle move forward. There really isn't enough room to point the wrench any way but toward the back. And since torquing is rotational I don't see how you can make it directional.
