Are 2011 Rear Shock's rebuildable?
Hi guy's, my 2011 Spyder RT rear shock has a slight air leak, are they rebuildable?
Reason: Expanded title to briefly ask the question... ;-)
Ozzie Ozzie Ozzie
Hi Peter, my bike doesn't have a compressor it's manual fill from a valve.
Ozzie Ozzie Ozzie
So is the bag leaking air? Have you done a bubble check to see where the leak is? If it's the bag you'll have to replace it! They do still have them! You may want to install the rock protector under the bag when you put the new one in!
Ok, you guy's are talking about an air bag, were is this famous air bag ?
The air bag sits in front of the rear shock and attaches to the frame and swingarm.
If you go to any CanAm PARTS site you look at all the FICHE's which will show 99% of all the parts that are used to build any Spyder / Ryker ...... good luck .... Mike
Ok thanks guy's, Wow it really is an air bag, never saw that on a bike. You learn something new every day.
Yeah, the air bag is what adjusts the ride height, which is load dependent. (Also, acts as a spring helper too.) Since yours is the manual fill, you must adjust the air pressure depending on the load. Most Spyders do it automatically.
My old 2014 was a straight RT, with the manual fill, so I would have to periodically check it because it would leak down slightly over time. (I bought a special hand pump for bicycle tires to check and inflate. DON'T use an air compressor.)
2020 RTL SE6
