Results 1 to 4 of 4
    Feb 2022
    Millersville, MD
    Spyder Any benefits from Elka Shocks after sway bar upgrade?
    I have a 2022 RTL and have already changed to Baja Ron sway bar. Unsure how much benefit I would get with upgrade to new shocks versus OEM. I installed in reverse order on my 2019 RTL and seemed to get good improvement from each one. Any thoughts from someone who has changed sway bar first and then added new shocks later, do you feel the benefit in terms of handling and comfort from the shocks warrants the hefty price tag?
    Last edited by Peter Aawen; 09-12-2023 at 01:39 PM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    I installed the BajaRon swaybar immediately after I purchased mine. I loved the “more positive” feeling it made especially in turns. After a couple years I “invested” in the stage 2 Elka shocks and I can tell you that I felt the improvement right away ..! It now goes into curves with a very confident feel to it. This is the (I.M.O.) the best handling experience you can achieve on this machine so I’m very glad I did it.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Aug 2020
    Il
    Quote Originally Posted by Dmetcalf View Post
    Did you noticed any harsher ride afterwards?
    21 Spyder base F3
    Aug 2012
    Central Coast, CA
    On my 2014 RT I did both. I did the Baja swaybar first and felt it needed more, then went to the Elka's. The ideal set up IMO, is the swaybar, then Elka's, combined with a good quality automotive tire up front. This will give you the best possible ride given the design limitations.
    2020 RTL SE6
