Page 65 of 80 FirstFirst ... 155561626364656667686975 ... LastLast
Results 1,601 to 1,625 of 1979
  1. #1601
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Rode the TN section of the "Snake" this morning. I'm getting pretty used to the Spyder, and I feel a lot better in the turns than I did a month ago.
    I don't miss 2 wheels in the least bit. So glad I decided on this F3s. I love everything about this machine. I found out though, that if you ride one of these things be prepared for lots of questions from riders, and just about everybody. You will become a Spyder Ambassador.
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
  2. #1602
    Active Member Pikester's Avatar
    Rio Rancho, NM
    Installed my position 5 Ultimate floorboards. Thanks Troop! I’m taking a trip to Sierra Vista, Az this next weekend to get the laser alignment done. After the Pedal Commander, Verdestein tires, & BajaRon's Ultimate Sway Bar, it rides/handles, much, much better.
    2023 F3-T , Petrol Metallic
  3. #1603
    Feb 2022
    very southern tip of Texas
    Installed an Apache 4800 case on the Lamonster PackRack. Thanx to SL member Haze for info, pics, and answering questions. Getting both Spyders prepped for the 2-day, 1,000+ mile trek to Spyders in the Ozarks.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
  4. #1604
    Active Member BigPoppa's Avatar
    Jun 2023
    CA
    Installed my heli-bars (thanks Troop!). For some reason my right side bar didn’t want to slide in all the way (even tried lubricating it with oil) so I had to use the old rubber mallet to tap it in. Not like I plan on removing it anyway.
  5. #1605
    Oct 2015
    Lynden, WA
    Oil and filter change. Added Show Chrome magnetic drain plugs from LaMonster.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  6. #1606
    Jul 2023
    S.E. Pennsylvania
    Ran some errands. A total of 10 turns and less than 7 miles for the day.
    Lee B
    2022 Can Am RT Limited
    2021 Honda NC750X DCT
  7. #1607
    Vermont
    I got a Sway Bar with Links installed on Saturday( 9/9/2023) at SpyderQuest @ Lake George, New York.
    Also at SpyderQuest I had them check the alignment on my 2023 F3 LTD Special Series. The Rolo Laser Alignment was not needed. I wanted something to go by from the get go.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Half Cover
    Show chrome Trunk Shock
  8. #1608
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Got out for a nice 50 miler. The weather was sunny and cooler than it has been.
    Joe
    2023 F3
  9. #1609
    Oct 2021
    TX
    I put a General Altimax RT45 on the rear today. Replaced the original Kenda with 7000 miles on it because the center of the tread was worn exclusively. I am running 18 psi and it seems to ride good. Maybe it’s just my imagination, but I feel like the bike handles better with new tire.
    2019 RTL
    2019 RTL , Blue
  10. #1610
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    Rode my 2012 RTS to my dealer and they did a valve check and put new gaskets on the valve covers. I also had them do a belt adjust and alignment after I put a new belt put on and had no way of figuring out the tension myself. Got some led bulbs too.
    Spyder felt great on the way home and vibrations hardly noticeable after the adjusting.
    Brgds Martin
  11. #1611
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Removed the pedalbox that was giving me the limp mode error and installed the pedal commander. I set it on sport mode +4 and man it has way more pep than the pedalbox sport mode.
    2021 RT Base - Petrol Blue
  12. #1612
    Active Member RodO's Avatar
    Jul 2009
    Montréal, Canada
    Oil and filter at an indie shop yesterday and I added Ride-On in the tires today.
    Ryde safe,
    Rod.
    '08 GS SM5 Full Moon -- after 15,000km sold May'11
    '10 RT A+C SE5 Full Moon -- after 30,700km traded in 2014
    '17 RTL Pearl White -- new-to-me in 2023
    "I guess its better to bend a valve in Missoula than to lose your mind in Bozeman", my wife said, patting my hand as if to console me. I winced and wondered if Phaedrus ever took the bus." -Peter Egan, Leanings
    CanAm Highway goes from Texas along U.S. Route 85 and Interstate 25 into Saskatchewan, Canada.<http://en.wikipedia.org/wiki/CanAm_Highway>
  13. #1613
    Oct 2015
    Lynden, WA
    Assembled a cane rack tied to the package rack. Adjusted all tire air pressures.
    Rode to AAA to get a Trip Tik for Carson to Bellingham future tour.
    Remounted my frunk caddy.
    David C
    2016 F3T
    Rear IPS Pack Rack
  14. #1614
    Jun 2023
    Tennessee
    I replaced the stock plastic/resin Sway Bar end links with the Lamonster links. I just didn't like the idea of plastic on my suspension system, and not sure if I actually need an updated Sway Bar. I'll ride like this for a while and see how it goes. They only took 10 minutes to install, and they're very well made.
  15. #1615
    May 2013
    Gladys, VA
    Took advantage of a sunny nice 70* day yesterday. Got in a short 25-mile ride. Got a few future projects stacking up in the shop:
    Gustafsson 17" windshield - https://bikescreen.com/collections/c...th-gp-hardware
    RLS Cat Delete - https://www.rlsexhaust.com/collectio...delete-muffler and
    SpyderPops BumpSkid - https://spyderpops.com/the-original-...els-all-years/
    Last edited by Peter Aawen; 09-15-2023 at 06:18 PM. Reason: Exposed hidden URL's to avoid spammers...
    Joe
    2023 F3
  16. #1616
    Jul 2023
    S.E. Pennsylvania
    I took the loaner bike back to the dealer to exchange it for my bike that was in for service. I left before dawn to avoid some of the Philadelphia commuter traffic. I took the scenic route from my home to the dealer in central Pennsylvania. It was a very pretty ride once the sun came up. I rode through Amish farm lands, up and down the foot hills of the Appalachian Mountains, across the Susquehana River, and into Michaux State Forest. Once the bikes were exchanged I repeated the ride in the reverse direction. It was a beautiful day to ride. Total round trip time of 10 hours, about 340 miles.
    Lee B
  17. #1617
    Aug 2023
    Central Florida
    Quote Originally Posted by Haze View Post
    Rode to AAA to get a Trip Tik for Carson to Bellingham future tour..
    Holy smokes….”Trip Tik”….I remember those handy little booklets. I would have guessed that they discontinued those years ago. I am happy that they still have those in their offerings..
  18. #1618
    Jul 2023
    S.E. Pennsylvania
    Went for a short morning ride on a beautiful day. Dropped down to ride around Valley Forge National Park. Afterwards we rode through Chester County and through 5 covered bridges. Knox Covered Bridge, Gibson Harmony Hill Covered Bridge, Sheeder Hall Covered Bridge, and Kennedy Covered Bridge. The final bridge was Rapp's Dam Covered Bridge located on Rapp's Dam Road. Bridges in Chester County are painted white instead of the traditinal barn red. 78 total miles for the day.
    Lee B
  19. #1619
    Rio Rancho, NM
    Rode 675 miles from Deming, NM to Sierra Cycles in Sierra Vista, AZ to get the laser alignment done, and then back home to Rio Rancho, NM. That was a long day!
  20. #1620
    Apr 2022
    Southern Norway
    Took out the halogen bulbs in my running lights (low beam) and put the new led bulbs in
    Wayyy better light on these dark roads over here. High beams are so far very good, so I will wait a while with those.
    Brgds Martin
  21. #1621
    Nov 2018
    Northern NV
    Installed Lamonster's cat delete, bar clamp with RAM ball and foam grip covers. Oh, and I washed it... we got caught in the rain last weekend near Lassen Park and hadn't had a chance until today.
    2017 F3T , Black, black and more black
  22. #1622
    Quote Originally Posted by grumpyoldretiredcop View Post
    So why'd you wash it again, if you got caught in the rain??
  23. #1623
    Jun 2023
    Tennessee
    Rode up to visit my son in the Blue Ridge mountains. Approx 80 mi RT. Nice day, but I had to don my real leather HD Shovelhead jacket because the mesh jacket flows to much air this late in the season. Fall is hear in ETN.
  24. #1624
    Jun 2023
    Iowa
    Quote Originally Posted by Dasmoetorhead View Post
    Did the new sway bar links improve your ride any?
    I am trying to decide if I want to start with just the links also.
  25. #1625
    Vermont
    I took a short ride.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
