Do these need to come off S2S RTL before panel removal?
Hey all,
I will soon be removing the right side panels on my 2022 S2S to add accessory wiring and Pedal Commander. I watched some videos and have a good grasp. That said, my S2S has deflector winglets attached, Are these simply attached to the backside of the panel or do they need to be removed prior to panel removal? Thanks for any info.
2022 RT Sea To Sky
They are attached to the panel. When you remove it, they come with it.
Peter Pan has struck again!
Originally Posted by
FrogmanDave
Excellent. Thank you
2022 RT Sea To Sky
And if you are going to install the adjustable deflectors, now would be the time to do it.
K80Shooter
I have a 2023 STS, and the adjustable deflectors are included on this model. Looking at the pic from this post, the 2022 has them as well.
vtrider
Yup
2022 RT Sea To Sky
vtrider
troop
Yup
I thought that it looked like it had them but just wanted to make sure.
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
