Results 1 to 21 of 21
    Jun 2015
    Ritzville, Wa
    Default A New way of selecting Reverse on the 2024's......
    I was just watching a video by Shawn Smoak who was showing one of the new 2024 Can Am's. He pointed out that the Reverse button, usually located on top of the left hand multi function switch was missing. He showed that now to shift into reverse you step on the bake, roll forward on the throttle like you do in the start up for the Ryker, then depress the - paddle button. Pretty neat.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Harrington, Australia
    Quote Originally Posted by gkamer View Post
    Ahhhhhhh. Thanks Greg, I was wondering about that……and great to hear Shawn has recovered
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2014
    Schenevus NY
    It strikes me that they took something that was relatively simple and made it needlessly more complicated
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    NorCal - Northbay
    Quote Originally Posted by Trbayth View Post
    Think about it, it is NO more complicated than the current method... Both press the brake, both press the - shift lever, just instead of reaching across and pressing a button, you roll forward on the throttle... same stuff, different wipe...
    I am in no mood for a new ryde, but I for one would love to have my 2015 this way... It is a much quicker way once the brain is retrained and safer if you are in a spot where you need to get it done faster....
    On a side note, those LED headlights on the '24's are FUGLY!!
    Last edited by Peter Aawen; 08-22-2023 at 07:58 PM. Reason: Bypassing 'unacceptable word' filter... :-/
    Chuck
    Jan 2021
    Descanso, CA
    Concur with hypurone, both ease of use and safety of operation.
    Mar 2021
    Maryland
    I also agree with Hyperone , those new f3's are fugly as can be. The section with the headlights looks like somebody took the pieces from an rt and just slapped them on there, it just doesn't look like it belongs there.
    It's like someone took a front end of a gremlin and try to slap it on a pacer. (those with some age on them will recognize my reference!) The only way you could make it uglier is make it in a manta green.
    I also have to give an attaboy to BRP for alienating all of the android users that are out there.
    2020 F3 SE6
    2020 F3 , Black
    Danbury Connecticut
    HUNH??????
    Am I understanding this?
    Instead of reaching over right to left to hit a button, you now have to advance the throttle ??
    So you run the engine rpm up and THEN put it in reverse ??
    Even with the brake engaged, wouldn't that hurt the transmission ?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Mar 2017
    Salisbury,NC
    HUNH??????
    not that way. REVERSE throttle action. like a Ryker
    Feb 2012
    Spring City,Utah
    No you are not. Advancing the throttle will not do anything to the engine rpms.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Oct 2020
    Vinton, IA
    IMO, using two hands do something one did is senseless. My left foot isn't doing anything, why not put a reverse button on the footboard?
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    .... Well what does " advancing the throttle " do .....?????? I know what it does on 14 RT, what does it do on your 12 RT ???? .... Mike
    HUNH??????
    Quote Originally Posted by Woodaddict View Post
    As Woodaddict mentioned, it's not OPENING the throttle or twisting Down to increase the revs, it's the Reverse of that, pushing the other way, just like you hafta do before starting a Ryker - it's actually CLOSING the throttle or pushing the top of the throttle Forwards, so it's not gonna do anything to the revs.... except maybe ensure that your engine IS at idle before the g/box tries to select Reverse!
    It's a good move. Very intuitive. Never liked the button. Change always brings consternation. But we didn't get from sandals to traveling to the moon without it.
    Granted, some change is a step or 2 backwards. But this one is going to be a crowd pleaser. It's a 'Try it, you'll like it' upgrade.
    Thanks for clearing this up ..... I was commenting on .... WHAT WAS WRITTEN .... I'd remove my comment , but I can't do that anymore ..... Mike
    Quote Originally Posted by hypurone View Post
    I guess we handle the reverse shift operation differently. First, you do not have to press the brake to shift into reverse. 1st gear yes, reverse no, although doing so is a good safety practice. Then I use my left thumb to push down the R button and hit the paddle with my left middle finger. I don't reach across to shift. Why do you?
    Durham,Maine
    2012 RTL , Pearl
    Vermont
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Aug 2019
    southwest oHIo
    First, you do not have to press the brake to shift into reverse. 1st gear yes, reverse no, ...
    Really? I guess I have gotten so accustomed to using the brake before leaving Neutral (in either direction), I never noticed that you don't have to. I'll have to try it this afternoon.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    NorCal - Northbay
    My 2015 F3S WILL NOT ENGAGE reverse UNLESS the brake is applied.... I reach across because my left hand is damaged to the point that if I "tweak" it the wrong way I have to sit and wait for it to recover.... Others may not be that dexterous or when the bars are turned full lock can't manipulate it that way... Any other questions I can help you with?
    Chuck
    Jul 2021
    IL
    I'm very comfortable with how I do it on my 2021 RT. Keeping both the starting of the engine and getting into Reverse not truly untuitive is also a deterrent to theft. I would guess most bike thieves would be stymied trying to start a Spyder, never imagining that the Mode button must be pressed. And being unable to get it into Reverse easily also would discourage a thief who would need to back the bike up to ride it away.
    I'm quite happy with my 2021, and if I were asked what changes BRP should make for future model years, changing the way to get into Reverse would not be high on the list.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Thanks for the clarification. I thought maybe a physical limitation is why you reach across. Makes perfectly good sense. The wording in the owners' manual for operating in reverse for both the F3 and RT is identical. Neither one explicitly states the brake must be depressed to shift into reverse. So it's interesting that one requires it and the other doesn't, even though the engine and transmission is the same for both. That, of course, does not mean the electronics are the same, which is what controls the shift operation. Maybe that was a change from MY 2014 to 2015. After all, 2015 was the first year for the F3.
