Results 1 to 25 of 37
    Active Member Pikester's Avatar
    Rio Rancho, NM
    Default Ultimate floorboards or smaller floorboards?
    Okay, I’m leaning toward purchasing the Ultimate floorboards, but I also like the smaller floorboards that look like they are slightly angled toward the rider. When riding twisties, I use the stock pegs to keep me on the trike & for those of you with floorboards, are you able to counter that force that is trying to throw you off?
    2023 F3-T , Petrol Metallic
    Quote Originally Posted by Pikester View Post
    I have floorboards that I made , and they are smaller than normal .... I like them, and I ride aggressively .... however It's on a 14 RT ..... so it may not be the same .... Mike
    Active Member Latrappe's Avatar
    Nov 2022
    Flaxton Queensland Australia
    I have the ultimate floorboards and love them as they make getting on and off the easier due to MS
    2019 Can Am Spyder F3S
    ICSI Ride Hand Brake Kit as my right leg and foot does not work that well due to MS
    The Ultimate F3 Floorboard
    Baja Ron Sway Bar
    Shad Saddle Bags
    Lamonster F3 PACKRACK
    SHAD 58X in Carbon finish - Expandable TOP Case
    Pedal Box
    IPS Belt Tensioner and Handlebar Riser from Lamonster
    K&N air filter
    INNOVV K5
    Wilbers Nite Line Shocks
    RLS Cat Delete
    Floating Rotors with EBC Brakes for the front
    I am now broke
    I Should mention the Boss has a 900 Ryker Ralli next to my bike
    2018 F3S , Monolith Black
    Oct 2015
    Lynden, WA
    Quote Originally Posted by Latrappe View Post
    I, too, have the Ultimate floorboards. I like the ability to move fore and aft on these floorboards while cruising. Grip the tank with my knees.
    Also, mounting the byke is much easier than stock pegs or a Third Peg.
    Last edited by Peter Aawen; 08-18-2023 at 11:45 PM. Reason: Removed post title - many can't see them & they mess with Searching... ;-)
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Here's another vote for the F3 Ultimate floorboards. There very roomy, comfortable, and make getting on and off much easier. I bought them before I even had my new F3s . Spendy though.
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Have you tried this?
    When in a turn to the left, push down on the right peg (or floorboard, whatever you have).
    Turning right, push down on the left peg (or floorboard, whatever you have).
    This WILL counter that "throwing me off" feeling.
    Try it!
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Active Member 3Tyme's Avatar
    Feb 2019
    SE Ohio
    Another vote for the Ultimate floorboards. I haven't found anything negative about them
    2015 F3-S , Silver
    Aug 2019
    Stoughton, WI
    I have P5 Ultimate boards on my F3S. You can still ride very aggressively with these boards.
    2022 RT Sea To Sky
    Vermont
    Another vote for the Ultimate F3 Floor Boards.
    I like these because I can stretch out more, or I can put my legs/or feet at different positions on the floor boards. My right leg I keep near the brake. When I am on the bike, I use the ultimate F3 floorboards or the passenger floorboards to get on/off the bike.
    I also use the passenger floorboards to get on/off the bike.
    When making left/or right hand turns my legs hug the gas tank.
    I have a 2023 F3 LTD Special Series.
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    Another Thumbs Up for the Ultimates. There are many fitment options for our F3's. Here are mine, on my F3L, they are #4's. It makes mounting (getting on) the machine much easier and more comfortable being able to shift your leg position. You won't (most likely) regret the purchase.
    Rio Rancho, NM
    Quote Originally Posted by Pooch View Post
    [/B][/COLOR]
    Try it!
    Hi Pooch, yeah, that’s what I do with the stock pegs, I’m just wondering if I will be able to do that with floorboards.
    Rio Rancho, NM
    Thanks for all the replies! For those with the Ultimate boards, are you able to ride fairly aggressively, as compared to the stock pegs?
    Nov 2018
    NW Minnesota
    Having an F3L, with the Ultimates, they don't come with pegs and I never ride -aggressively- so I can't answer that question for you.
    Feb 2018
    Texas Hill Country
    I have large floorboards on my 2021 RTL and I employ that method on our twisties.
    Started doing this on my Gold Wing trike many years ago... its just a normal habit now - don't even think about it.
    Let us know what you decide and how it goes.
    Cheers!
    Rio Rancho, NM
    Thanks for all the help everyone! I’m about 99% sure I’m going with the Ultimate floorboards. I have new Vredestein Quatrac tires coming next week and then my laser alignment on 9/15, so I’m thinking the Ultimate’s will be the next mod. Ride often & ride safe!
    Mar 2021
    Maryland
    Another vote for the ultimates, I'm in position 5 and have no problems riding in a spirited fashion. If you look at my sig I also got the F3 oversized brake pedal from the vendor that has the line-x sprayed on and it matches perfectly with the floorboards.
    2020 F3 SE6
    2020 F3 , Black
    Rio Rancho, NM
    Quote Originally Posted by CloverHillCrawler View Post
    I like that brake pedal! Do you have an adjustable or non-adjustable brake rod?
    Active Member RobDekker's Avatar
    May 2021
    New Brunswick, CANADA
    Another vote for the Ultimates.
    2021 Spyder F3-S Special Series
    Monster Fuel Injection Stage II
    K&N Air Filter
    Lamonster Cat Delete Pipe with Baffle
    Akrapovic Sinister Exhaust
    Baja Ron’s Anti-Sway Bar Kit
    Elka Shocks Stage 3 Front, Stage 4 Rear
    F4 Customs 32” Windshield
    Pedal Commander
    Lamonster F3 Brake Rod
    Shad SH36 Side Cases
    Crampbuster
    Mar 2021
    Maryland
    Non-adjustable.
    2020 F3 SE6
    2020 F3 , Black
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    Another vote for the ultimate floorboards. I ride aggressively and will admit that switching from the pegs to the boards took me a little getting used to but now I love the flexibility. If you feel like you need to plant your feet while riding aggressively, you can use the catch on the outer edge of the floorboard where the peg used to be as your bumper.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    Mar 2021
    Maryland
    I have had the floorboards on since I bought the F3 so I have just learned on going with a combo of leaning forward into the turn, shifting foot position back, and "squeezing the tank" with my knee's /thighs.
    2020 F3 SE6
    2020 F3 , Black
    Member narygancy's Avatar
    Jul 2022
    Pennsylvania
    I know I'm late to the game here. I also installed the Ultimate FB's and love them. I'll mention one advantage to them I haven't read yet. When I'm riding for an extended time I can actually stand up and stretch my butt while the bike is moving. Can't do that with traditional floorboards.
    I also recommend the matching rear floorboards. They make an easy mount/dismount for me and my wife.
    Pricey, but worth it.
    I installed highway pegs because on my 2-wheeler I used them all the time. Not so much when I put them on Miss Scarlett, they just kinda extend the foot space a little. But they do look good.
    2016 S6E , Red
    Jun 2012
    Longmont, CO
    Quote Originally Posted by narygancy View Post
    I almost mentioned it and then deleted it because I wondered if I'd get flamed. I agree this is a great feature.
    Rio Rancho, NM
    Do you have highway pegs with the Ultimate floorboards?
    Sep 2021
    Fredericksburg, VA
    I love my Ultimate floor boards.. My only problem with them is the lack of vibration dampening. All my other bikes always had rubber that lessened the normal vibration of the bike. Harley probably had the best, the rubber inserts were mounted with rubber tabs so the actual insert sat above the metal floorboard. Other then that they work great.. All the positives, talked about above, out weight this little negative.. I know they are expensive, I think it's still a value. When you consider the cost of other aftermarket floorboards then adding highway pegs it's really not that much more
    RiderDuke
    My Ride
    2021 Glacial Blue Metallic F3-T
