Results 1 to 5 of 5
    Aug 2018
    Ohio
    Default Is there any deductible on the "Best" warranty?
    Hi, all. We have our RTL in for a left control cluster replacement that is causing the parking brake failure. Does anyone know if there is a deductible on a Best warranty claim?
    Last edited by Peter Aawen; 08-15-2023 at 04:11 PM. Reason: Expanded title to briefly ask the question.... ;-)
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Quote Originally Posted by casey111 View Post
    https://can-am.brp.com/on-road/us/en...d-service.html
    YES! T.P.
    Mar 2017
    Salisbury,NC
    now that's interesting??????? left hand control cluster causing parking brake problems??? I think your dealer is throwing $$$ at a problem that has to do specifilly with the PB motor or micro switch. your likely to find out you need to spend more money on correct diagnosis.
    BEST should be $50 per occurance
    Aug 2018
    Ohio
    I did read that a bad parking brake switch could cause this issue. My codes are P0571, P1571, U0128. Thanks for the deductible info.
    Nov 2013
    Central Texas
    Quote Originally Posted by Woodaddict View Post
    Yep, $50.00
