Results 1 to 9 of 9
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Default Where/how do you run the USB Power Cord for phone?
    My F3S has the USB port inside the frunk. How are you running the cord from the handlebar to inside the frunk?
    Last edited by Peter Aawen; 08-13-2023 at 05:35 PM. Reason: Expanded title to briefly ask the question.... ;-)
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
    Aug 2013
    SF Bay Area
    You don’t. You add a USB to the dash area.
    Kinda like this. https://www.slingmods.com/can-am-spy...port?vehicle=1
    2021 F3 Ltd , Magna Red
    Northern Kalifornia
    I ran a 14 gage fused wire directly off the battery up and out under the seat with an SAE connector on the end. Then I can split off to USB or any other 12v connector I wish. I charge my phone, GPS, Sena, and 2 heated jackets off that line. Simple easy and very cost effective, and easy to install. When not in use, leave rolled up under the seat. Also, I use it to connect to a battery tender during the winter.
    Jun 2023
    Tennessee
    That's probably what I'll do
    Northern Kalifornia
    Quote Originally Posted by Dasmoetorhead View Post
    Put star washers on the battery bolts. I ran mine through a small flexible wire loom tubing from the battery to the seat area just for extra protection. Good luck.
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    I parasited the power for my dual usb in the blank switch spot off the driver seat heater switch. 2020 RTL
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Florida Swamp
    Plugged it in the customer convenience outlet under the left inspection panel, and ran it into the tank bag. Got a plug on it that allows removing the tank bag.
    2019 F3-S , Black & Silver
    Northern Kalifornia
    I also eliminated the useless analog dash gages and installed the cigarette type receptacle on one side and a dual USB with and volt meter on the other side. I also installed another double USB/volt meter in the empty switch spot right below the steering head. So, I've got 12v power coming out everywhere. Frunk, trunk saddle bags under the seat, and to my trailer when I pull it.
    Feb 2020
    CT and ME
    I fished a USB cable from the frunk up to the handlebars.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
