Results 1 to 6 of 6
    May 2023
    South Carolina
    Default '22 F3 Base - any ideas on Mounting racks for bags?
    Hello peoples, in a dilemma here. I’m trying to mount a lamonster ips rack and the Shad 3p mount system. I have a 2022 f3 base. So I do not have the grab bars and do not want them as my bike is being kept for a solo rider. But I do want the luggage ability. The lamonster rack states for use with all f3 models but my bike has different plugs on the back. Leaving me with quite the gap. Any ideas on what I should do? Picture below to see what I’m talking about.
    Thank you.
    2022 F3 Base , Gloss Black
    Active Member 3Tyme's Avatar
    Feb 2019
    SE Ohio
    Are you talking about the gap between the shad bracket and the frame or the gap around the ips mount and the stud? Its been awhile since I mounted the shad brackets, but I think I had to draw the brackets in tight with the bolt. If you want to talk about it let me know and i'll PM you my #
    2015 F3-S , Silver
    May 2023
    South Carolina
    Quote Originally Posted by 3Tyme View Post
    So my F3 Base has these nubs and not the hand grab bars. The nubs don’t exactly fit the rack. I believe they will with the Shad mount but I’m trying to use both a rack and side saddle bags.
    Feb 2019
    SE Ohio
    pm sent
    2015 F3-S , Silver
    Oct 2023
    Detroit, MI
    I used Lamonster's bungee buttons in place of those rubber pieces. There was still some space, but they held the IPC rack in place.
    2022 F3 Base with BRP 2-Up kit
    2022 F3 Base , Black
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    I have the Shad saddlebags on my 2019 F3 base, plus a rear rack.
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
