Page 16 of 17 FirstFirst ... 6121314151617 LastLast
Results 376 to 400 of 405
  1. #376
    Jul 2018
    Glasgow, KY
    Ordered the Can Am Comfort Seat, I'm not expecting a miracle but hoping for some improvement at least. It doesn't take long for butt burn to set in with that too soft stock seat.
    My Ryker seems stable as can be on a smooth road at interstate speeds. With the cruise set at 80 I can turn loose of the bars with no drama other than a slow drift to the right. It's a little different story on our worn and patched rural roads, but I'm hardly noticing now that I've gotten in a few more miles. Taking tight fast curves with bumps and dips in the road can be a little unnerving though, it that where an upgraded sway bar and end links might be a benefit?
    Sarah
    2022 Ryker Sport
  2. #377
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Received the steering damper the other day so going to install that on this week. Also have some stickers to add.
    2021 RT Base - Petrol Blue
  3. #378
    Active Member Badmotorf1nger's Avatar
    Mar 2023
    New York
    Showchrome full size brake pedal. Love it.
  4. #379
    Active Member StalkyTracker's Avatar
    Jan 2022
    USA
    Picked it up.
    2023 Ryker Rally - Heritage White III
    Sport Windshield
    GPS Holder
  5. #380
    Jul 2018
    Glasgow, KY
    ^^Congratulations StalkyTracker!
    I ordered the saddlebag bracket from RykerLyft on FB. I've got some SKB cases I'm hoping to use, so we'll see. That plastic spoiler on the maxmount was a bear to remove, it pretty much had me so Doug just started wrestling with it and it finally popped out no worse for wear. Sort of like the nose piece did when I installed my radiator guard, I thought sure I'd break something pulling that thing off. The ins and outs of this plastic bodywork takes some getting used to.
    Sarah
    2022 Ryker Sport
  6. #381
    May 2021
    Upstate NY State
    I got the wife what is referred to as tank trim for her rally with the name of her bike imprinted in it. I had to paint it the color of her accent trim (hot pink). I installed it yesteray. Looks really nice. I'll try and get a pic of it when the rain stops.
  7. #382
    Jan 2009
    austria
    reached today 30.000 miles ..on roads like this !!
    https://www.youtube.com/watch?v=p-tve0dK8QM
  8. #383
    Jul 2018
    Glasgow, KY
    I installed the BajaRon sway bar and end links kit. Used a Dremel to cut the factory sway bar, worked well and wasn't too scary
    Sarah
    2022 Ryker Sport
  9. #384
    Jan 2021
    Oklahoma City
    I installed the BRP Adventure windshield. Easy 20 minute job.
    2021 Spyder RT Limited (Sea-To-Sky)
    2022 Ryker Rally
  10. #385
    May 2021
    Upstate NY State
    Added a little more color match to the wife's Rally. Added 3D printed covers and some more color match to the top case and saddle bags. Also removed the can-am stickers on the air filter cover and replaced with the name of her bike in color match.
  11. #386
    Jul 2018
    Glasgow, KY
    Called up BajaRon and talked to Paige, ordered the K&N air filter for the CVT side. Friendliest service ever, and much better price than the local parts places. It's amazing how much dirt you see on the CVT filter compared to the engine air filter.
    Sarah
    2022 Ryker Sport
  12. #387
    Oct 2021
    Ontario
    Haven't even got it home yet and just bought the Comfort seat, Comfort passenger seat and the folding backrest.
  13. #388
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by Raven View Post
    That's my set up too. I'm trying to find a bag that mounts on the back of the backrest and doubles as a solo rider backrest when folded down. Found a few but I'm not sure they would work.
  14. #389
    Sep 2019
    illinois
    I double checked the torque on the Rally wheels today. I had rotated the front wheels about three rides ago, and I changed the rear drive oil one ride ago of 70 miles. I put a scissor jack up level with the 8" extension resting on it while torquing the rear. That helps a lot. Then went for a 55 mile ride through three different County parks.
  15. #390
    Jul 2018
    Glasgow, KY
    SKB cases on the RykerLyft bracket:
    Bolted an aluminum plate on the back of the case, then bolted the case to the bracket. The rack behind the seat is one we happened to have on the shelf. Three bolts go through the rack, maxmount, and RykerLyft bracket.
    Sarah
    2022 Ryker Sport
  16. #391
    Mar 2023
    New York
    Put on carbon fiber upper and lower panels.
  17. #392
    Jul 2022
    PA
    Installed M2 Shocks, yesterday
    Have a plain old 2019 900 Ace, and upgraded the shocks to M2s from RPS. Took the dive and ordered a full set of shocks. Did the install on the fronts and took it for a spin... Wow, it's light years better than it was. Installed the rear a few hours later, but it jarred pretty bad over bumps. Marcus had reached out to me asking how the install went, so I answered. He immediately told me what adjustments to make to the rear shock and was spot on. Now the ride and handling are spectacular. I couldn't be any happier with both the product and the customer service.
    Last edited by Peter Aawen; 07-09-2023 at 07:11 AM. Reason: Moved Post title into text - many only see Thread titles, and post titles mess with Searching! ;-)
  18. #393
    Jul 2018
    Glasgow, KY
    Had a local hole-in-the-wall tire shop mount up a Hankook Ventus V2 on the rear rim. He charged $15, I gave him $20.
    Sarah
    2022 Ryker Sport
  19. #394
    Jul 2018
    Glasgow, KY
    Changed the oil and filter. Big, big thanks to Pantera for the toilet paper roll tip, worked perfectly.
    Sarah
    2022 Ryker Sport
  20. #395
    Oct 2021
    Ontario
    Brought it home on Tuesday.
    After waiting over three months for road construction to get done I finally was able to pick up the Ryker.
    A friend drove me down to get it.
    Took some back paved roads with low traffic just to get used to three wheels.
    Only went for a front brake a few times, had to laugh when I went to put a foot down at a stop.
    Had to go back to the dealer on Wednesday, one key wasn't working, and the bars were off to the left. (Nice morning for a ride tho)
    They (Lockhart's in Courtland Ontario) took it right in and had me out in twenty minutes.
    They have been super to deal with.
    Went and put close to a 100 miles on it on some main and back roads.
    Got a big headlight flash and waves from a couple an a Spyder going the other way. (my first)
    After not riding for almost two years, I feel a little beat up, in a good way.
    Loving it, But the wife says I have to stop doing my Aerosmith impression.
    "BACK IN THE SADDLE AGAIN"
    Now if it will stop raining, I can go out some more.
    Sorry for the long post.
    Bruce
  21. #396
    Active Member nightfalcon's Avatar
    May 2023
    New Zealand
    Hi Bruce
    I've also been off a bike for a couple of years. Picked up my new Rally a couple of weeks ago and was grinning like a loon under my helmet riding it home.
    To keep on topic: I just got a Cardo Spirit HD comms for riding on the Rally, I'll be able to hear my GPS now, so no excuses for getting lost... again
    Last edited by Peter Aawen; 07-14-2023 at 01:47 AM. Reason: Caps; ' 's; & ridding... ;-)
  22. #397
    Jan 2022
    USA
    I didn't actually do it today but over the last few weeks and finally got a couple of pics:
    Installed the Can-Am glove box organizer; helps a little, really like the piece that attaches to the glove box lid.
    Installed the Hopnel tank bra.
    Installed the Show Chrome handlebar end weights. I had some minor vibrations on the grips and these have eliminated it.
    Installed the Providence Spyder Accessories water bottle holder. Works as advertised and comes with an adjustable bottle holder for my coffee thermos.
    Installed the Can-Am knee pads.
    Installed the Can-Am tank bag. It's small and not a lot of room for storing items but functions as advertised and doesn't interfere with gassing up.
    Installed an Ultimate seat with backrest. Not completely broken in yet but way more comfortable than the Rally Comfort seat that came with the bike.
    Sport Windshield
    GPS Holder
  23. #398
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Quote Originally Posted by greer View Post
    ...Taking tight fast curves with bumps and dips in the road can be a little unnerving though, it that where an upgraded sway bar and end links might be a benefit?
    Sarah
    Have you already upgraded to 400 mm shocks? Sorry if you already posted, but I now only lurk occasionally.
    Not only longer, with increased ground clearance, but the full length springs are so much better.
    https://www.amazon.com/GZYF-Motorcyc...00XVH4NVG?th=1
    For my 2020, 400 mm was the max travel of the front suspension.
    See post 13
    https://www.spyderlovers.com/forums/...00#post1545853
  24. #399
    Oct 2021
    Ontario
    Put the Can-Am Sport windshield on the other day.
    WOW what a difference. On the Ryker I felt like I was going faster than I was, not now.
    First ride I noticed a lot less wind buffeting, Looked down and found I was 30kph over the speed limit.
  25. #400
    Jul 2018
    Glasgow, KY
    Quote Originally Posted by SportsterDoc View Post
    See post 13
    Sorry I missed this SportsterDoc. Yes, I went with the 400 mm shocks first thing. Thanks again for posting the details, ordering was a piece of cake. We just returned from a 10,000 mile trip up through the Yukon and I am pleased as can be with the Ryker. And thanks again for the advice and suggestions early on.
    Sarah
    Sarah
    2022 Ryker Sport
