Results 1 to 25 of 25
    Jul 2022
    Washington state
    Default 7x12 trailer owners - do you have trouble loading? Any fixes?
    Do you have trouble loading from the rear ramp? Such as bottoming out on the way in? Have to do anything to raise the front of the trailer to do that?
    Last edited by Peter Aawen; 07-10-2023 at 01:16 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Quote Originally Posted by captcharles View Post
    Most folks just have a couple of 2 x 6 boards ( 4 ft long will be enough ) .... or release the tongue and tilt the entire trailer..... Mike
    Jul 2022
    Washington state
    So the 2x6 are laid down on the ground before the loading ramp?
    western Colorado
    Yep, that works too. I use the dip at the end of driveway
    Oct 2021
    TX
    I have a 7x12 enclosed trailer with a deck height of 17". The rear ramp/door is 6' long and I have no trouble rolling right in the trailer while it is hitched to the motorhome.
    2019 RTL
    2019 RTL , Blue
    I would put the boards 2 ft.on the ramp and 2 ft before the ramp ..... put a couple of bolts at the RAMP end of the board so it doesn't SLIP - in or off the trailer ramp ..... Mike
    Jul 2022
    Washington state
    Do you use 3 ramps?
    Do you use 3 ramps?
    Well I had to, because I was putting my RT into my Pick-up ( No Ramp ) .... You only need two for the front tires, the rear won't be affected by the Ramp angle .... and you should have enough traction to prevent slipping. ..... Mike
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Do you use 3 ramps?
    I did not; just two for the front tires. The rear tire/frame had clearance.
    May 2014
    Benson, NY
    I don't have a 7x12 but this cured the bottoming out problem with my 6x10.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Jul 2022
    Washington state
    Quote Originally Posted by Bensonoid View Post
    What are the wood blocks for?
    Looks to me like the front wheels will climb up the rear end of those 'wood blocks' just at the right time to lift the belly of the Spyder a bit higher & stop it scraping on the top of the ramp; then as the back wheel starts to climb the ramp & in its own turn, lifts the belly clear of the top of the ramp, the front wheels will go down the other side of those blocks.
    It's effectively reducing the angle of the step up onto the ramp and the angle of the ramp over onto the trailer bed, basically extending the length of the angled ramp so that the belly of the Spyder doesn't/can't catch on the top of the ramp/rear edge of the trailer bed due to the Spyder's low ground clearance. I reckon it's a pretty smart way of doing it too!
    Bossier LoUiSiAna
    Quote Originally Posted by happyspyder2039 View Post
    Same when I rented a 7x12 utility. Sorry, didn’t measure the ramp/gate, guess it was 4, maybe 5 foot. If on flat ground, definitely too steep & hi centered. Blocked the street temporarily & backed to the curb at the driveway, which made it almost level ** hi centered & trailer hitch hit pavement **
    May 2014
    Benson, NY
    Exactly
    Last edited by Peter Aawen; 07-10-2023 at 10:53 PM. Reason: Fixed quote display ;-)
    Sena 20s
    Hamburg pa
    Look up tilt a hitch they work great
    Feb 2012
    Spring City,Utah
    My trailer is 7 x 14 and loads with no bottoming. I did add an 18 inch full width flap that eases the transition from ground to ramp. It is attached with three large hinges and folds inside against the ramp.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2022
    Washington state
    Quote Originally Posted by Littleantlers View Post
    Looks like they're not available. Several sites said no longer available. Looks like a great solution though.
    Aug 2019
    southwest oHIo
    Hopefully the boards will work, but if you do have to "release the tongue ...", please make SURE you have the wheels blocked IN BOTH DIRECTIONS and also have some bracing under the trailer to HOLD the tilt. But then you also need to be able to release the tilt (in a controlled manner), so personally, I would avoid releasing the tongue and tilting the trailer. Boards are cheaper and SO much easier.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Quote Originally Posted by Steve W. View Post
    ..... and releasing the tongue might not be a good idea for most folks ..... Thanks .... Mike
    Jul 2022
    Washington state
    Pictures?
    Feb 2012
    Spring City,Utah
    Pictures?
    I will take some in the morning
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    It all depends on the make and model of your trailer. I have an Aluma Executive Series trailer and I do not have to do anything to load it. The Executive Series comes with a longer gate which is a Bi-Fold gate and my Spyder RTL runs right up on it with no clearance problems. A buddy of mine has an older trailer that he has issues but instead of using and having to carry 2x6 boards he went to the local RV dealer and bought some of the RV leveling blocks which there are lots of types and styles to choose from, and he backs his truck up on them to lift the rear which in turn will lift the tongue of the trailer decreasing the angle at the rear of the trailer.
    https://www.campingworld.com/maintai...veling-systems
    2022 RT Limited , Silver w/ Black and Purple accents
    Jul 2022
    Washington state
    Quote Originally Posted by campermac View Post
    Been there, done that. I had a Polaris Slingshot and did that to load, plus a beavertail and taller bumpers on the ramp door.
    Feb 2012
    Spring City,Utah
    Pictures?
    The ramp is used to soften the transition from ground to ramp as there is a pretty good-sized lip there. The ramp and the transition at the top of the ramp is gentle enough that Spyder clears the edge without any trouble.
    Last edited by Peter Aawen; 07-22-2023 at 11:09 PM. Reason: Fixed attach display ;-)
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    We have a 7x10 trailer that we haul everything in. Never have an issue. It has a 4' wire mesh tailgate. But if we did have an issue, I would simply lower the hitch leg and crank it up the front of the trailer while still attached. I've done this with all kinds of trailers It will lift the back of the vehicle with no problem. Thus lowering the rear of the trailer and reducing the approach angle.
    finding a suitable locations for the trailer that lowers approach angle is easier. But not always possible. Especially if what you are trying to load is not running.
