Will there be enough room in a 6' x 10' Trailer to tie down RT?
22 RTL
Looking to get a 6x10 enclosed cargo trailer. I've seen posts that say it will fit. But is there enought room with the Spyder loaded to get around to for tie down straps to be attached to it and the floor? I'm a big guy and concerned about that.
Reason: Expanded title to briefly ask the question... ;-)
You might want to measure the ramp opening width on the 6 x 10. After measuring several, I found out that some were not wide enough and one only had 1/2 in clearance on each side of the wheels. I went with a 7 x 12. This size gives enough clearance to get around to tie down my RTL.
I also went with two axles for better stability and braking and rear pull down jacks so I can load and unload while not being hooked up to the truck.
Adj removable backrest, KOTT radiator screens
Double horn (118db), Lamonster mirror fix
FOBO 2, Trunk rack, Afterburnerz taillights
Drinks2go cup holder, replaced the seat strut
Garmin Drive Smart 71 GPS, Large brake pedal
White pulley, Pedal Commander, Trunk Strut
Laminar Lip wind deflector, side windshield wind deflectors
Home made belt guard, Shorty antenna
Show chrome wide windshield, Belt dampener
Top cuffs and Mirrors
7x12 enclosed trailer
2021 RTL Dark Chalk Metallic
Skip H.
I had one, the ramp was wide enough, but the cables brackets and cables that lifted the door were too narrow.
I sold it and am looking for something a little wider.
Originally Posted by captcharles
22 RTL
I'd get one with an access door up front. Most of the v-nose trailers have that. Also, install a winch to pull it in. Good luck.
2014 RTL Platinum
I think you will be sorry if you don't get a trailer that is at least 6' wide and 12' wide. You'll have lots of "stuff" you may want to put next to or behind the Spyder.
We love our Big Tex SA35 single axle trailer. Tows great too!!
Reason: .
2014 RTL bought in 3/20 with only 6,000 mi.
Came with Garmin 660
Car tires in 5/20; Elka stage 2 front shocks in 10/21
I have a 7’x12’ enclosed trailer with a V-nose. I think 6’ x 10’ would be awfully tight especially when trying to tie it down. With 7’x12’ I am able to carefully walk around the Spyder without climbing. An added bonus, the V-nose 7’x12’ allows for storage of our riding gear, built in shelves and carrying other items, oil, gas can, cleaners, spare tire, telescope, etc..
2019 RTL
I agree with jchadwi above that 7 foot wide is much better for access around the Spyder once you get it into the trailer. Note that most trailer widths are quoted to the outside of the walls. I bought a 7x14 with tandem wheels and I'm very pleased. Tandem axles are not really needed for this small trailer with the light load, but towing is much more stable and they are much more controllable in the event of a blowout. Ask me how I know. Tandems are also less sensitive to getting tongue weight exactly right to prevent sway.
2021 Spyder RTL chalk/black/chrome bought in March 21. Previous rides: 2019 Spyder RTL, Orange/chrome. 2015 Harley Heritage, 2002 Harley Heritage, 77 Harley Electra Glide, 75 Harley Electra Glide, 72 Harley Sportster (first bike bought new)
My Spyder Mods
Rider backrest, F&R cup holders; F3 handlebars; BRP LED driving light; LaMonster front fender and mirror turn signals, LaMonster Saddlebag lights, Auxito LED rear turn signal blubs w/ built in load resistor; Brake lite modulator/flasher; LaMonster flags on trunk; Garmin Zumo XT. LaMonster Bluetooth adapter for Phone & GPS through Spyder speakers. LaMonster floorboard risers; FOBO tire pressure monitors, Vredestein front and rear tires; BajaRon sway bar.
Yea, I think you'll hate yourself if you get a 6'x10' trailer for 5 1/2'x8' spyder. If you do and you can get it in the trailer at least you won't have to tie it down because there's not enough room for it to go anywhere. Lots of good advice in the above posts.
2021 RTL Marsala Dark Edition 4.13.2021
Lamonster Riser
Spyder Extras Docking station
Zumo XT (my own Plug & Play cable)
WrapMySpyder Carbon fiber partial kit.
Baja Ron ultra performance sway bar and end links
2015 RTS SM6 Intense Red
born on date 3/2015 (mine on 9/12/15)
Sold on 4.13.2021 33k of fun.
I use a 7x14 with tandem axles and a Vee nose with a front access door. I have room to move around the Spyder keep other Spyder related gear and equipt. in there. I was not very much more than a 7X12.
Reason: axel... ;-)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
i have a 6X12 covered single axle. no problems for me. the wheels are outside of the box so no wheel wells. measure the opening size as you will need 51 inches to get it in there.
Have NO Idea what opening your talking about with only 51 inches!...Bill
If in Doubt, Don't Do It!
