Will this tire fit
Yes, it will fit the fronts of any Spyder with 15 inch wheels .... I have never heard of that brand, so why do you think it's a good choice ???? ....Mike
The FRONTS???
That size (225/60-15) is better-suited for the REAR tire.
Yes, it will probably fit, but your speedometer accuracy might be off a bit.
HER ride:
2017 RT-S SE6 Pearl White
My rides:
2000 Honda GL1500SE
1980 Suzuki GS850G
Ozzie Ozzie Ozzie
Originally Posted by Steve W.
The FRONTS???
Looking at its specs, most likely that tire'll bring your speedo/odo/trip meter's closer to 'accurate' than the OEM Tire sizes ever did!
Yes, it will fit. Let us know how it works for you if you go this route. (Rear Tire)
I first need a video of how to get the rear tire out of the 2022 RT-L.
Can Am is completely Alien to me I'm use to Harleys.
I almost bought this same tire when I needed a rear tire several months ago, but I didn't. I had never heard of the brand plus the reviews talked about looks but not much preformance information. The tire I did go with was the Riken Raptor HR in the size of 215/60/15. I fellow Spyderlovers member suggested it. I'm happy with the tire so far.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
The FRONTS??? e.
... When I clicked on the Ad at the top of the page it said in large black type '''165/ 65 - 15 " .....Mike
https://www.youtube.com/watch?v=7t6sLLfl6aM
If you find a video for the 2020+ RTs, please post the link.
2022 Spyder Sea to Sky Mystery Blue
2009 Suzuki Boulevard M50 SE
I have not looked closely at a '20+, but I'll bet that video will work. Yeah, the plastic is all different, but if you know which end of the screwdriver to pound on, I'll bet you can figure it out.
HER ride:
My rides:
2000 Honda GL1500SE
1980 Suzuki GS850G
See my post #27 in this thread, it contains some tips that I compiled from various other threads but don’t remember seeing them all together previously.
https://www.spyderlovers.com/forums/...81#post1643681
The 2020+ are not too different in regards to changing out a rear tire so videos from older models on this subject translate well to the 2020+ models.
2021 Spyder RT Limited (Sea-To-Sky)
2022 Ryker Rally
Did the brake rotor have to come off to have the tire mounted.
No it didn’t need to come off.
2022 Ryker Rally
HER ride:
My rides:
2000 Honda GL1500SE
1980 Suzuki GS850G
But it makes it easier to work around if you do!!! And getting the rotor back between the pads and getting everything lined up at the same time would be a pain!!
Strangely enough I didn’t have any trouble. I did have to R&I the calipers, but I didn’t have to back the caliper pistons off to get the caliper back on the rotor, just made sure I was lined up with the rotor and not cockeyed at all, slipped right back on.
2022 Ryker Rally
Depends on the tire mounting machine and the guy doing the mounting.
Forceum Hena 225/60R15 Fits my 2022 RT No problems. Rides better, more stable, Speedo is usually right on or 1 mph off. Haven't tried in the rain yet. 3,000 mi.
Reason: Moved Post title into text - many only see Thread titles, and post titles mess with Searching! ;-)
1650 right now and handles the rain perfectly.
Which one, the Forceum or the Riken?
Reason: Caps & ' 's ;-)
Well, SLICE quoted CBX Bob ... so my guess is the Forceum ..... Mike
