Results 1 to 15 of 15
    Active Member mstella101's Avatar
    Jul 2013
    Glen Ellyn, Il
    Default Any opinions on New Rear Tire Costs?
    WOW just talked to dealer about changing out my rear tire on my 17 F3-L. Almost fell out of my chair - 3 hours work time at $152 per hour and $180 for a new Kenda! Fronts would be 1 hour for each tire at $152 and $105 per tire. Shocked is what I was. I know dealers gotta make a buck, but those times seemed a little long. Looking for some opinions. I know it's another tire thread, but I haven't seen any asking about price recently. Just wondering?
    Last edited by Peter Aawen; 05-26-2023 at 08:54 PM. Reason: Expanded title to briefly ask the question... ;-)
    Sep 2012
    Stetson, Maine
    If it was me in your situation, I would ask dealer if they would mount a tire that you provided. If not a good tire place should be able to due it for a lot less. You would have to take the tire off yourself. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    I just purchased 2 front Vredenstein Quatracs for my 2016 F3L for $111.82 apiece and then my dealer mounted and balanced them for 1 hour ($120) total labor for both. I would think you should look for another dealer. The Kendas leave a lot to be desired, and I cannot believe he is selling them for $103. Quatrac rear tires are $123.78 ea.
    johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Quote Originally Posted by mstella101 View Post
    WOW just talked to dealer about changing out my rear tire on my 17 F3 L. Almost fell out of my chair. 3 hours time at $152. per hour and $180. for new Kenda! Fronts would be 1 hour each tire at $152. and $105. per tire. Shocked is what I was. I know dealers gotta make a buck but times seemed a little long. Looking for some opinions. I know another tire thread but I haven't seen any about price recently. Just wondering.
    The quote sounds "mercenary" to me. Way to high. Maybe on purpose because they don't want to mess with tires.
    Mar 2021
    Arizona high country
    I ordered 2 Vredestein tires for the front and an Ultimax for the rear. Local tire shop mounted and balanced the fronts for $20 total. Took the rear to my Canam dealer and he changed out the rear for $108. You need to find a new dealer
    Sep 2018
    Australia
    Name them.
    Jul 2013
    Glen Ellyn, Il
    Cobwebs, before I name them I'm gonna talk to the service mgr and store mgr- they weren't around, We'll see if he doesn't look at a client whose bought from there and had all work done there as loyal, then... ARtraveler, I think you are right about doing the rear, sure does seem to be a pain. I am going to check for tires at your alls places and see about getting it done elsewhere. Even tho I am from Chi-town I may just have to take a trip to Lamontster Garage. would be fun to get away. Cause they sure do treat people right there! HAHA
    I happened to check the TIRERACK website and the Riken Raptor HR (which I have on my RT & LOOOOOOOOOOOVE it. )....has a delivered price of $97.50 ..... It's the lowest priced Quality tire - REAR TIRE ..... good luck .... Mike ..... If you go to LaMonster, call them first and ask if that tire can be sent to His shop for mounting.
    Oct 2020
    Vinton, IA
    A year and a half ago, I paid my dealer $198.00 ( 2 hrs. @ $99 ) for rear tire installation; I supplied the tire of my choice. The invoice was marked "install customer supplied tire", presumably to absolve the dealer of any issues with BRP for not pushing OEM rubber.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    If you make the trip to Lamonsters Garage you will like it. We have always been treated fair. And...they know what they are doing.
    Durham,Maine
    I just got the Altrax for $110, took the tire off myself and had it broken down, mounted, & balanced, all for $20!! I will say I haven't yet found the secret to taking that rear tire off without having a bear of a time with belt alignment!! But I got it!
    2012 RTL , Pearl
    Mar 2021
    Maryland
    After I got the whole belt alignment and tension thing figured out it (never had to do it with a jet ski as it was just engine, shaft then impeller) it unlocked the rest for me. There are several videos on how to do this.
    And it is not that hard to do, it just takes the time to overcome that voiding the warranty fear before you start turning wrenches; at least with me that is what was holding me back for a little while.
    After I had the re-frame done, I figured anything bad would be blamed on it from that point on and they would void the warranty, and that overcame my fear of turning wrenches on it. That and every dealer and tire place I called refused to mount my tires for me.
    I finally broke down and bought that Harbor Freight ATV Lift Jack and Jack Stands and it was history from there, and glad that I did it too, as I have found out that most of BRP's dealerships aren't worth their weight. I am glad after 2 years into my Spyder that I did find one that can help me out when needed. I have to drive past 2-3 other dealerships on my way to Grantsville, Pa, but they are well worth it. They really helped me out with getting the alignment done on the front end and also spotted another reframe issue that I had. One tie rod all the way in the other all the way out.
    2020 F3 SE6
    2020 F3 , Black
    The secret is to remove the REAR Schock Bolt ..... this gives you the extra slack so that the Adjusters won't have to be touched .... good luck ... Mike
    Jul 2013
    Glen Ellyn, Il
    I admire and am in awe of you DIYers- especially for the back tire! Taking off the fronts won't be a problem. I'm doing my homework to get this done .I'll keep you all in the loop. Thx for all the help and suggestions.
    Mar 2021
    Maryland
    Here is the great rydes video on how to get this done on a F3 , I like his videos... short and to the point. They helped me out along my journey.
    2020 F3 SE6
    2020 F3 , Black
