Results 1 to 12 of 12
    May 2023
    Tucson, Arizona
    Default Is it possible to do a DIY reflash on an F3?
    I am strongly considering a "stage 1" reflash for my 2018 F3. I'd rather do it myself, both for the fact I like doing things myself (and I have some experience) and less downtime. Do you know if this is possible?
    Thanks!
    Last edited by Peter Aawen; 05-18-2023 at 10:38 AM. Reason: Expanded title to briefly ask the question... ;-)
    indpls in
    yes go to monster also go stage two you will be much happier
    May 2023
    Tucson, Arizona
    Stage 2 sounds good, but they want you to send in your airbox lid, I think? I should be able to modify it myself. I'm pretty happy with a drill, a Dremel, a torch, and a really big hammer.
    indpls in
    two 1 inch holes in lid
    Jan 2021
    Descanso, CA
    brian -- I suggest you talk to Monster. The Spyder has a knock sensor and it's likely Monster will say if you ride easy Regular gas will work in a pinch.
    May 2023
    Tucson, Arizona
    I talked to a monster once. Thanks!
    indpls in
    yes works if have to or carry a bottle of octane boost i do
    May 2023
    Tucson, Arizona
    Quote Originally Posted by fatboy View Post
    That's actually a great idea. I havent actually picked up the bike yet (Saturday), but I come from 35 years of motorcycles, and not used to having any storage space!
    NorCal - Northbay
    Quote Originally Posted by brian10x View Post
    Thanks!
    You cannot do it yourself if you want the Monster/WickIt tuning.. You can do it yourself with a DynoJet Powervision but I don't feel the tune is as "refined".... If you do it thru WickIt or Monster (one in the same) I highly recommend the Stage 2...
    Chuck
    Jun 2019
    Deltona FL
    Check out Dynajet. Easiest set up for the do it yourselfer.....
    Feb 2020
    CT and ME
    Yes you can do it yourself with the Monster tunes. But it requires purchasing the MyGenius device along with the tunes. The airbox lid is easy to modify with a 1 inch hole saw. I bought a spare airbox lid and cut the holes in it myself. Monster sent me the Stage 1 and Stage 2 tunes along with the MyGenius and I can switch between stock, Stage 1 and Stage 2 as I want. It takes about 5 or 10 minutes to retune.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Aug 2019
    Stoughton, WI
    Give Jamie Long a call at Fuel Moto USA and get some info on a DynoJet PV3. Free lifetime map support and you can make tweaks if you so desire..
    2022 RT Sea To Sky
