Results 1 to 10 of 10
    May 2023
    NJ
    Default Will a Windscreen Help block the wind? What size for a Ryker
    Had back surgery and find the wind hitting me at speeds over 35mph painful on the back. Will a windscreen help block the wind hitting me from the waist up? What size for a Ryker? I'm 6' 5"
    Last edited by Peter Aawen; 05-05-2023 at 11:14 PM. Reason: Expanded title to briefly ask the question... ;-)
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    I know Madstad makes a good windshield. I have the adventure windshield and I'm 5' 10" and it does ok. If I was to get another I would go with madstad. You can call and talk with them.
    David
    Active Member Badmotorf1nger's Avatar
    Mar 2023
    New York
    16" showchrome works great for me at 6ft tall. Maybe he 20" version would be better for you since you're taller.
    Active Member linguine's Avatar
    Feb 2023
    AZ
    I'm sure you will find one for you. But remember that the bigger the windscreen, the bigger the sail. Cross winds aren't fun with large windscreens.
    Ride safe; shiny side up, greasy side down.
    best,
    linguine
    2020 RT Limited , Chalk Gray
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by Badmotorf1nger View Post
    What seat are you using on yours. I have the Ultimate which sets me higher in the seat.
    David
    May 2023
    NJ
    Solo comfort seat
    Member Green1's Avatar
    Sep 2018
    Lebanon PA
    I had same issue as you, wind was brutal at speeds like you mention with no windscreen. The small can-am windscreen was not much help for me at 5'7" I got the madstad windscreen and it took that issue you have away. I'd suggest getting the one that allows you to open the frunk without moving the windscreen all the way up(sport). That was a pain to do all the time, so I then got the one I suggest and it's so much nicer! I got the 16 inch one so you probably want to go taller. F4 custom windscreen is very nice also. Good luck!
    Dec 2022
    Florida - Wimauma
    F4 is the answer. I went and bought 2 other windshields before this one. What a mistake they were.
    Spent the $400 and got the F4. Worth it in spades.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    I have the Puig universal windshield. It is short but slightly larger than the can am shield. Its just enough to get the wind off my chest and deflected to my helmet area plus it allows me to turn my head side to side without feeling like my head is going to get ripped off.
    Mar 2023
    New York
    Quote Originally Posted by Warlock View Post
    David
    23 rally with stock rally seat
