Results 1 to 18 of 18
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    Default Is it possible to delete start up routine?
    Is it possible to delete the start-up routine using BUDS/Mega?
    I had an ECU Upgrade from Jase in Qld and the start-up routine was gone.
    I had an ECU Upgrade from Monster and I think the start-up routine was gone (can't remember) but they couldn't disable DESS as Jase could.
    I can now disable DESS but would like to delete the start-up routine as well...
    Any thoughts?
    Last edited by Peter Aawen; 05-05-2023 at 07:05 PM. Reason: Expanded title to briefly ask the question... ;-)
    pres ride
    2014 RT-S
    bike is WIP
    bike has endured elect spike (was jump started incorrectly)
    still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
    Feb 2016
    Not that I can find. I have the Stage 1 flash from Monster FI on my 2020 RTL and the routine was bypassed. Our 2021 F3L has the same flash and the startup routine is still there...
    2020 RT Limited , Marsala Red
    Northern Kalifornia
    Yep, stage 1 or 2. Turn the key hit start and go.
    Jun 2021
    OR
    You can also turn the key, hit the mode button right away and hit the start button. No need to wait for for the screen to show.
    2021 Spyder RT Limited
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Quote Originally Posted by shardt View Post
    This is exactly what I do.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Active Member linguine's Avatar
    Feb 2023
    AZ
    yup. why bother with programming attempts?
    Ride safe; shiny side up, greasy side down.
    best,
    linguine
    2020 RT Limited , Chalk Gray
    Harrington, Australia
    Even on a ‘14 RT, which the OP has, Shardt ??
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member RangerRick's Avatar
    Jul 2022
    Coos Bay, Oregon
    Not on my 2013 St. That one reason I just purchased a used ECU on ebay and will have it flashed with a stage 1 from
    https://wick-itperformance.com/shop-...-can-am-spyder
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Aug 2019
    southwest oHIo
    I believe that 'feature' showed up in '16 or '17. Earlier models had to wait.
    My sister and her husband both have '14 RTLs. They turn the key ON, then put their helmets on while the bike does its 'thing', then they start the engines and leave. My wife has a '17 RTS. It's so much nicer to just turn the key ON, press the MODE button once, then the starter.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Sep 2015
    Chilliwack, BC. Canada
    Don’t be too fast saying that Pete. I’ve ried that routine on my ‘14 RTS many times and I have yet to have it work. The only time that I can just turn the key and start it is during quick fuel stops....SOMETIMES!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Quote Originally Posted by bigbadbrucie View Post
    Yes, that was the question I was asking, Brucie. I do not believe I have ever seen anyone with a ‘14 be able to do a “quick start”
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2008
    Hesston, PA
    The police models from BRP are instant start...My 2014 with the Monster stage 2 flash is instant start...BUT I still need to hit the mode button to get the dash to display...BUT IT INSTANLY STARTS AND DRIVES/RIDES AWAY...larryd
    Aug 2019
    southwest oHIo
    I don't remember if I saw it in a manual or posted here, but I think you have about 5 minutes before the system completely resets itself, so a "quick fuel stop" might qualify.
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Sep 2015
    Quote Originally Posted by Steve W. View Post
    Yup.....and most of my fuel stops are longer....that’s why I said “might” qualify.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Dec 2020
    Hartwell, Ga
    I do it all the time.
    Aug 2020
    Il
    It takes all of what, 3 seconds to get through the startup sequence. First world problems.
    21 Spyder base F3
    Jul 2022
    Coos Bay, Oregon
    10-12 seconds on my 2013 Spyder ST
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Feb 2012
    Spring City,Utah
    If you turn on your Spyder as soon as you walk up to it, by the time you get your gear on, it will be ready to go also.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
