Results 1 to 5 of 5
    Aug 2020
    Falling Waters, WV
    Default Had the sprocket recall done, now it's got a vibration! Which Belt Tensioner?
    I had my 2017 F3T serviced for a recall on the sprocket. I now have a vibration between 60 & 65 mph which I did not have before. The mechanic suggested installing a belt tensioner. Is there any difference between the tensioner from BRP and Lamonster Garage?
    Last edited by Peter Aawen; 05-06-2023 at 08:46 AM. Reason: Expanded title to briefly ask the question... ;-)
    Feb 2020
    CT and ME
    Huge difference in quality and robustness. Get the Lamonster product.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by Scooter1942 View Post
    Yeah,LaMonster did his homework…..it is the better choice.
    2019 F3L , Covid Blue
    Apr 2015
    Lodi WI
    Belt vibration is reduced when the belt is adjusted to 180lbs on a krickit device. Dealers typically go around 200 lbs.
    B.S. - Spyders don't NEED a belt tensioner - PERIOD ...... they screwed something up .... changing that sprocket should NOT have caused those vibes ...... as Dennis said lower the belt tension ( IMHO 160 lbs. wheel on ground ) I'll bet the Tech set your tension to fACTORY SPECS WHICH IS WAY HIGHER THEN 160LBS. .... GOOD LUCK ....Mike
